Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Flat tire  (Read 10421 times)
Re: Flat tire
« Reply #50 on: February 04, 2019, 07:27:03 PM »
I finally managed to get some useable readings from my (aftermarket Chinese cheap) TPMS:
- Taking off in the morning. Front: 2.4 bar (temp 2°C). Rear: 2.0 bar (temp 2°C)
- Landing at work after 50 km of realtively constant speed. Front: 2.6 bar (temp 5°C). Rear: 3.2 bar (temp 10°C)
Do I have water inside my tires?
(c;
PS: the ambient temperature as shown by the TPMS was consistent with the one of the dashboard. And the altitude from start to finish was roughly the same (within 50m).
No, just a problem typing, rear from 2.0 bar to 3.2 bar!  :005: :005: :005:
Re: Flat tire
« Reply #51 on: February 05, 2019, 01:03:32 AM »
An "argument of authority" doesn't work either!
That's... not what an argument from authority is. An example would be "Aristotle says that rise in pressure in heated tyres is from water vapour." What I gave you was an argument based on physics, for which you can check the figures yourself. I also pointed out repeatedly that the low water content of nitrogen is why it is used in race bike tyres, which you can check for yourself.
Re: Flat tire
« Reply #52 on: February 05, 2019, 09:02:04 AM »
Damn!
The correct value is 2.9 bar cold rear.
Re: Flat tire
« Reply #53 on: February 05, 2019, 09:17:01 AM »
Sorry, I'm just a poor Froggy trying to make you believe that I can actually speak English ;-)
What I had in mind was probably something more like 'argument of assertion', you know like 'I say it is true so it is'.
Your physics look right, but I don't see any direct proof that water is the cause of unexpected figures.
As for racing bikes, now this argument is more like of authority: 'Racing teams do it so it must be based on something true'.
Sorry, but this could serve as a clue at best, not a proof.
I had more than one debate about proof with my colleagues when I was a researcher. They ultimately deemed me 'stubborn radical science unbeliever' or something like that ;-)
Offline KenW
Re: Flat tire
« Reply #54 on: February 05, 2019, 12:16:18 PM »
This thread is going around in circles to no avail.  Something like "the low water content of nitrogen is why it is used in race bike tyres" is pretty meaningless on its own.
Dry air would be low in water content too, and probably cheaper than nitrogen.  So moisture content alone doesn't seem a good reason to use nitrogen.
Now what was the topic again?  I think it got lost somewhere.  (And I confess to being as bad or worse than most at steering threads off topic.)
Offline Deep6blue
  • Bike: Several
  • City / Town: Washington
Re: Flat tire
« Reply #55 on: February 06, 2019, 03:58:00 PM »
Moisture content in the air is directly related to the airspeed velocity of an unladen swallow. European swallows and African swallows are different though, so the coconut carrying capacity could differ. Plus if the coconut absorbed the moisture from the air it would become possibly necessary for 2 swallows to share the load between them. Then again, if the air was extremely dry, and 2 swallows were carrying the coconut, the coconut husk may actually ignite, causing and in flight disaster, or a coconut bomb...
What are we talking about again?
Re: Flat tire
« Reply #56 on: February 06, 2019, 04:08:10 PM »
*Originally Posted by Deep6blue [+]
I can't believe you didn't factor in the husk drag coefficient? Some people, just part explanations……!  :033:
Re: Flat tire
« Reply #57 on: February 06, 2019, 04:30:44 PM »
I have no clue what this thread is about. It turned into my YouTube recommendations list  :745:
Offline Hawk281
  • Bike: tiger 1200 2018
Re: Flat tire
« Reply #58 on: February 06, 2019, 08:01:02 PM »
i think it is about having tires at both ends of the motorcycle, which are inflated with some type of gaseous substance. Not really sure now.:745:
Offline KenW
Re: Flat tire
« Reply #59 on: February 06, 2019, 10:36:40 PM »
Must admit, I'm finding the whole thread a bit hard to swallow.  Nuts, I say.
