Sorry for my English but I use a translator.
I would like to buy you the tool to undo the splined nut in order to access the large oil seal.
I live in France in Avignon, could you give me the price with the delivery (fast if possible)?
Thanks in advance.
I've had a batch of the sprocket tools made up. They're just 6mm thick mild steel plate cut out with a water jet or laser.
If anyone need/wants one I'll finish it by hand and cut the groove and post them out. The cost will £20.00 each + P&P to where ever you are. message me for a quote on postage with your address.
I can also supply the oil seals as well.
The large one is £12.00 each
the small one is £6.00 each
the large O ring for the outside of the seal holder is £.050 each
I'm not doing this to make money. This is a cheap DIY repair which will hopefully save owners a lot of money and grief so no warranty is given or implied.
