Home
Search
Members Map
Photos Gallery
Login
Register
Forum Rules
Forum Help
Contact Us
06 Mar 21, 08:05 AM
Please
login
or
register
Tiger 1200 Explorer
Main Tiger 1200 Explorer Discussion Boards
Tiger 1200 Explorer - General Discussion
Coolant loss
06 Mar 21, 08:05 AM
Pages:
1
2
3
Go Down
Author
Topic: Coolant loss (Read 4827 times)
#20
CaptainTrips
Explorer God
Topic Author
Bike: '13 Explorer
City / Town: Vancouver(ish)
Country:
Re: Coolant loss
Reply #20 on:
September 30, 2016, 03:09:57 PM
Originally Posted by
FL_Explorer
I take it the rad cap must be difficult to access. Not sure I've even seen mine, so it must be tucked away pretty well.
It's not that bad, but you do have to remove the plastic from the left-hand side of the tank. The stupid thing that T did was not putting it on the right-had side of the tank like everybody else. Consequently they had to add an air purge valve to the right hand side of the bike (because you want the bike on the sidestand to do this) which is not accessible unless you remove the fuel tank and rig it to run with the tank off.
Logged
"The test of the machine is the satisfaction it gives you. There isn't any other test."
-- Robert M. Pirsig
#21
Will Morgan
Explorer Master
Bike: Explorer
City / Town: Ross on Wye
Country:
Re: Coolant loss
Reply #21 on:
October 01, 2016, 10:22:37 AM
CaptainTrips
Why not use the centre stand ? If you want/need the bike to lean off vertical just put a bit of plywood under one foot of the centre stand ?
Logged
#22
CaptainTrips
Explorer God
Topic Author
Bike: '13 Explorer
Country:
Re: Coolant loss
Reply #22 on:
October 01, 2016, 04:49:51 PM
Will Morgan
The way we usually do this on other bikes, is after you refill the coolant, you run it with the rad cap off and the angle of the bike on the side stand insures that as the coolant heats up, air that is trapped in the radiator works it way to the high point and burps out of the filler. Yes, I guess that I could rig something to hold the bike at an angle to the right to simulate the sidestand effect.
Update: I pulled the radiator cap and took a closer look at it. I noticed that T have put a heavy sticker on the top of the cap, with universal markings on it. Then I took a blow dryer and heated it enough to peel this sticker back. There was coolant under the sticker, in the depression in the center of the cap! Also, the whole thing is loose, with the center column of the pressure release valve passing through the cap with a flange on top. It rattles when you shake it. It's like the heavy sticker was actually meant to form a seal across the top of the cap. !?
Logged
-- Robert M. Pirsig
#23
CaptainTrips
Explorer God
Topic Author
Bike: '13 Explorer
Country:
Re: Coolant loss
Reply #23 on:
October 01, 2016, 05:53:41 PM
I picked up a Prestone branded 1.1 bar (16 lb) radiator cap (part #14-1008-6 T-16R) at the local autoparts store. Will give this a try and see what happens.
Logged
-- Robert M. Pirsig
#24
CaptainTrips
Explorer God
Topic Author
Bike: '13 Explorer
Country:
Re: Coolant loss
Reply #24 on:
October 03, 2016, 01:32:01 AM
Well, took it for another ride this afternoon and it leaked. This time, I had the plastic off, and I could see that coolant was getting past the hose clamp (although this continued to be an intermittent thing -- sometimes it would leak for a while and then stop, and sometimes it would not leak at all.
I went to the hardware store and bought a proper hose clamp in the plumbing isle (stainless steel, 50% wider than the OEM one, better screw mechanism) and the leak has stopped (so far). I have put the plastic back on (which is guaranteed to make it leak again) and will see what happens tomorrow on the commute. Have a trip planned for the end of this week, so hopefully we got it this time.
Logged
-- Robert M. Pirsig
#25
supernac
Explorer Pro
Bike: 2014 XC
City / Town: Springfield
Re: Coolant loss
Reply #25 on:
October 04, 2016, 12:04:51 AM
I'm not sure why triumph decided to use screw clamps, its almost a guaranteed leak at some point. The constant pressure spring type clamps are much better, albeit harder to get on/off.
Logged
#26
Scubadvr
Explorer Master
Where did I leave my keys?
Bike: 2014 Green XC
Country:
Re: Coolant loss
Reply #26 on:
December 21, 2016, 09:44:21 PM
A week ago, I arrived home from my daily commute (it was 18F (-8C)) and noticed my left pants leg and boot had coolant on them. Not a whole lot, looked more like splashes. When I got off the bike, it was all down the left side of the bike and on the crash bar, maybe about 1/8 cup all told, not a tremendous leak, and not actively dripping.
Today, I had the time to pull the fairing and have a look.
The source was obvious.
So, having read up on this thread and a couple of others, I was figuring on replacing the clamp, but since I didn't have one, I thought I'd just tighten the one that was on there. It took another 1 1/2 turns to get really tight.
I cleaned everything up, then started the engine. Figured I'd go ahead and run the "12-minute tune-up" while I was at it, to give it a decent time to see if it would leak or not. It took a good 20 minutes to warm up enough to turn on the fan, then another 12 minutes, then I shut it down. No more leaks! Time will tell if I need to replace the clamp, but for now it looks like it's OK.
To celebrate, I want for a short Winter Solstice ride down by the local frozen lake and waterfall. It's always lovely this time of year.
Logged
The journey
is
the destination!
#27
CaptainTrips
Explorer God
Topic Author
Bike: '13 Explorer
Country:
Re: Coolant loss
Reply #27 on:
December 21, 2016, 10:15:23 PM
Scubadvr
I thought that tightening it up cured my problem too, and then it started leaking randomly again. I think that the OEM clamp creates a gap that actually pinches the hose causing a leak.
Anyway, the ultimate cure for me was to put a better quality hose clamp on it.
Logged
-- Robert M. Pirsig
#28
Bluto2013
Explorer Member
Living the Dream, baby!
Bike: TigerEx1200 2013
City / Town: Kinshasa
Country:
Re: Coolant loss
Reply #28 on:
February 22, 2021, 06:17:20 PM
CaptainTrips
Without starting a new topic, (is that not cool?) I was searching on our forum for some discussion of why the radiator cap is tucked under the tank? On the Left?? There are 10 design solutions from goose necking the filler, to just cutting out 4oz of fuel from that front lobe that occludes the filler cap. Why make it so hard to access? Just changed my coolant on a moto that is new to me. The service manual says to rock the bike left and right to burp out the trapped air? WTF? Also, to run it and burp it with the fuel tank/power extension cord? Tank off? Triumph just turned a simple job into a 2 man job with an expensive dealer part. Also, the lowest drain is at the bottom of radiator? I know that I left about 1/3 of the coolant in the machine.
My last moto was a 97 BMW, and it aggravated me that the battery was tucked under the tank. Tank removal is not a small thing! Messy and smelly!!!
All cycles have design compromises, but it astounds me how little they think of owner's who want to care for their own cycles. Who does this? Who is responsible? What was said at the meeting? If I learned more, it would just make me more cynical and bitter
Logged
Bluto2013
#29
CaptainTrips
Explorer God
Topic Author
Bike: '13 Explorer
Country:
Re: Coolant loss
Reply #29 on:
February 22, 2021, 10:31:43 PM
I am pretty sure that I could R&R the rad cap with the fuel tank trim removed (but the fuel tank still installed). There is also a drain plug in the block.
I refilled the rad and vented it with the bike clamped in a wheel stand (no rocking the bike) and the fuel tank installed and had no issues.
There is a vent on the right-hand side rad hose that you can open. I just filled the rad, let the bike idle for a while with the rad cap off until the thermostat opened, and then shut it off and topped it up and put the cap on. Any extra air worked its way out to the overflow bottle.
Don't fill the overflow bottle more than the lower level mark on the bottle.
Logged
-- Robert M. Pirsig
Pages:
1
2
3
Go Up
Resinating noise
NIMike1973
Today
at 07:35:21 AM
Heated grips behaving very oddly!!
Electrical and Lighting
T800XC
Today
at 02:44:54 AM
Removing TPMS
T800XC
Today
at 02:41:19 AM
New rider in Southampton
New Members
Captain Tom
Yesterday
at 10:51:46 PM
First decent ride on the Alpine, love it apart from the mirrors!
Captain Tom
Yesterday
at 10:43:52 PM
rear brake pad wear
Brakes and ABS
Hawk281
Yesterday
at 04:00:12 PM
Triumph Tiger 1200 Explorer Service Manual
Parts, Accessories & Clothing For Sale
FrenchTiger
Yesterday
at 09:23:43 AM
Dunlop Trailmax Mission Tires Another new tyre for us.
Tyres and Wheels
Qship
March 04, 2021, 08:55:43 PM
Tex gearbox needed
Cmpharkin
March 04, 2021, 12:20:39 PM
First time bike owner: very basic questions I have no clue on
General Maintenance and Servicing
Dragon88
March 04, 2021, 12:17:25 AM
