Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: TSAS ABS and TC disabled during hard acceleration  (Read 4538 times)
Offline PTwizz
  • Bike: Tiger1200XC2015
  • City / Town: Norfolk
Re: TSAS ABS and TC disabled during hard acceleration
« Reply #30 on: October 11, 2018, 01:43:56 PM »
If you see the combination of those system warnings as you describe, you can be fairly confident that it is the same software failure.
A genuine hardware failure (e.g. wheel speed sensor) would be captured by the ECU, which would record a DTC (fault code) to be read from the OBD port, either by your dealer, or by yourself if you have the tool.
Offline kenw
« Reply #31 on: October 12, 2018, 12:40:39 AM »
As a now-retired programmer, I know that any complex software is almost certain to contain bugs.  Its just whether they manifest themselves as a problem.  You hope that comprehensive testing will find most of them.  (A 'bug' is only a bug if it actually occurs.  Code that doesn't get executed doesn't count.)
I've had a software bug appear a few times on my T1200 now.  I reset the fuel display, and it shows 51.1L/100km average usage, stuck on that until I reset again, at which point it returns to normal.
But even 'normal' is not quite right.  I'm riding at a constant speed, the instantaneous L/100km figure is say 4.5, I reset the figures, and the average starts off at 6 or 7 or more, gradually coming down to the likely correct figure.
Small anomalies, not affecting the reliability of the bike, but software bugs all the same.
What I'm finding odd, is that we don''t all suffer the same bugs.  Only one person reporting here of TSAS/ABS/TC issues on acceleration.  No-one else has mentioned fuel metering anomalies.  Only NiK reporting a T1200 that won't run.  (Though I think he has a hardware fault.)
So where is Triumph's communication point for reporting back what are most likely software bugs?  Going through dealers seems to be such a variable experience.  You'd think Triumph would want to know directly about ECU anomalies so they can investigate them.
« Reply #32 on: October 12, 2018, 01:59:47 AM »
There is a Software Suggestion Box. It is located on the north face of Everest, about 50 m from the summit (if I recall correctly).  :038:
« Reply #33 on: October 12, 2018, 09:01:30 AM »
In a classical Root Cause Analysis, this would point toward a central processing bug. If the kernel is bugged, it can cause many different errors when incorrectly reacting to different situations (and judging by the sheer number of sensors in our bikes, there has to be many).
I'm more and more convinced that Triumph don't master their own product (which indicates that it's not really their product, but probably some gizmo outsourced from the cheapest contender in their Request For Proposals).
« Reply #34 on: October 12, 2018, 09:41:53 AM »
No different than many manufacturers I think, Brembo, Tokico, Nissan, Showa, WP, Sachs, Yuasa, Bosch, Michelin, Dunlop, Metzeler, umpteen unknown manufacturers of seat mouldings, body panels etc, the list goes on an on. I cant think for one minute Triumph bang out a tender doc for a 6-axis IMU and then take the lowest bidder who comes out of the woodwork. Granted, they didn't design the electronics specifically but I would suggest they spent some fair amount of time in a collaborative approach with the chosen vendor.
Maybe a little more thought by Triumph on how to deal with drawn out issues such as this is in order though. There can only be so many intelligent parts to this bikes electronics and you might of thought a diagnosis test rig which could be plugged into a loom temporarily replacing the bikes intelligent systems could be designed. Each dealer needn't have one just one or two per geo which could be Fedex's around as required.
« Reply #35 on: October 12, 2018, 09:59:54 AM »
Of course they have many suppliers.
But the one we're talking about is the central processing unit. The 'brain' of the bike. The device without which the bike might simply don't start at all.
Only a complete moron would treat this part lightly.
Unfortunately, the various bug reports here tend to show that it was the case...
Offline tiger955
  • Bike: explorer
  • City / Town: Barwell
« Reply #36 on: October 12, 2018, 01:39:49 PM »
Had a 65 plate Gen 2 that had a fault light and warning on display for TSAS fault, three trips to dealer and no fault codes stored but Triumph instructed dealer to change rear shock, problem sorted, well done Triumph  :046:
« Reply #37 on: October 12, 2018, 03:12:02 PM »
Perfect example of a bad error handling design!
How can you possibly design a system that is unable to detect and report faults?!
And when you see such blatant flaws, how can you possibly go on as if everything was normal?!
Apparently, development best practices aren't enforced by Triumph!
Offline anaheimtex
  • Bike: 2014 Explorer xc
  • City / Town: anaheim
  • Country: California
« Reply #38 on: October 23, 2018, 03:05:54 PM »
All bikes, all brands, all makes, have buggy units or lemons.  fault codes and lights are best guess by the computer.  a rock dings a wire to the thermostat and the thermostat code pops up.  2016 BMWs are turning off randomly while driving.  lights turn off and engines backfire.  KNOWN issues form the most complex machines ever designed.
Offline Teealb
  • Bike: 2016 Explorer XRT
  • City / Town: Munich
  • Country: Germany
« Reply #39 on: June 10, 2019, 10:34:14 AM »
Hi guys'n'gals,
Last year, when I was asking for advice on this issue (in a separate thread), I eventually convinced Triumph Germany to investigate and fix.  They eventually admitted that there was an issue within the software controlling all these systems and that Triumph UK were addressing it.  After a few months, I was asked to bring in my bike for a software update.  Did this and all seemed well for the few rides I had left before the bike came off the road for winter.  So now that we are well into the year's riding season (remember, I'm in Germany), I have had a few instances where I get TSAS, ABS & TC system failures all at once.  Normally this seems to be linked to shut down and then start up sequence.  I noted that it mainly occurred if I had stopped the engine using the kill switch and then started up again shortly afterwards (within a minute or so).  However, the fault was not reliably repeatable.  Anyway, just got back from a ride down to Croatia and back.  During this ride, we had mixed weather -  from icy rain to 30deg C.  The bike did, on a few occasions, give the warnings on start but they were reset by ignition off / on action.  THEN - on the last day, whilst riding back through Austria, with very high temperatures, I started to consistently get these failures.  Each time I would stop, ignition off then on again and to be honest, it was hit or miss if the bike reset the systems.  At one point, I did note that the system went in to a re-calibration of the TSAS and ABS.  Once it had done that, all the systems came back on line.  BUT then shortly after, failed again.  This continued until the air temperature started to drop.  I would say at around 25 deg C the problems seemed to go away.  Not been out to test the bike since.  One thing I will point out - when discussing these warnings the first time with Triumph dealer in Munich, they advised that it was purely an indication issue and that the systems were still working normally.  However, on that last day, when I was having repeated failures, I did notice a marked change in the braking system performance.  So, any support, advice or comments on other experiences out there to date (My bike is a 2016 XRT)
Previously owned: SS50, RD125DX, YDS7, Katana 550, FJ1200, SV650S, TL1000S.
