Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: fork reassembly  (Read 374 times)
Offline poochar24
  • Bike: 2017 XRT
  • City / Town: Chalfont, PA
fork reassembly
« on: December 01, 2017, 06:54:17 PM »
2017 XRt ...... have forks apart to replace springs with 0.95 kg/mm rate
While draining the oil on the right fork upside down (with smaller damper rod out)
the small spring and red thing came flying out ..... not sure order or direction they go
back in (see picture) ??????
........ also nothing like that was in the left fork (sound right?)
The damping cylinder in the left hand fork is for compression damping while the damping
cylinder in the right hand fork is for rebound damping.
Thanks,
Eric
Offline Fazer
  • City / Town: Tyneside
Re: fork reassembly
« Reply #1 on: December 01, 2017, 10:38:11 PM »
I’ve no idea how the fork is reassembled but maybe this exploded diagram from World of Triumph will help:
http://www.worldoftriumph.com/triumph_motorcycle_parts_locator?block_01=&block_02=100076559-0-2&block_03=560053
Good luck - Dave
Offline poochar24
  • Bike: 2017 XRT
Re: fork reassembly
« Reply #2 on: December 01, 2017, 11:19:51 PM »
Thanks Dave ....... yeah, sadly they don't go into detail in that exploded view!
Eric
Offline MarksMotorCycleParts
  • Forum Sponsor
  • Bike: 1200 Explorer
  • City / Town: Bath
Re: fork reassembly
« Reply #3 on: December 07, 2017, 01:19:05 PM »
Eric,
I've not worked on those forks so can't say for sure, but i think the red thing is your damping adjuster. You should put it back in with the pointed end downwards.
Having different internals in the left and right fork is not unusual these days, so don't worry about that.
Mark
Offline poochar24
  • Bike: 2017 XRT
Re: fork reassembly
« Reply #4 on: December 07, 2017, 01:33:54 PM »
Thanks Mark !!!
Yes ...spring goes over pointed end of red "thing" ..... then pointed end
down into the fork first (inner damper rod goes over top of the red guy)
Also pretty sure there is same deal in left fork (just did not fall out when I turned over)
Eric
