Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: headstock adjustment  (Read 684 times)
Offline fubbytucker
  • Bike: 2013 Explorer
  • City / Town: Yorkshire
« on: December 03, 2017, 11:38:13 PM »
The headstock bearing on my 2013 tex was replaced earlier this week as it was notched.
On riding now the steering feels very stiff, more stiff than I've ever had on a bike.  I'm sure it is overly tight and I'm finding the bike is very hard to ride smoothly, all adjustments to direction are having to be forced.
Is this adjustable in any way or should I be waiting to see if it loosens as it beds in?
  • Bike: Red Skin
Re: headstock adjustment
« Reply #1 on: December 04, 2017, 09:23:36 AM »
*Originally Posted by fubbytucker [+]
If it was the case, then every new Tex would have this problem.
And I had two and none of them was affected.
« Reply #2 on: December 04, 2017, 10:15:32 AM »
There is adjustment. On the steering stem there is an adjuster nut & a lock nut. The adjuster should be tighten to 40Nm, slackened off, then re-torqued to 10Nm. Then the lock nut is tightened against the adjuster. Is it possible when the lock nut was done up it turned & tightened the adjuster more the 10Nm? In theory it requires special tools = a castellated socket to torque the adjuster & a C spanner to hold it while the lock nut is tightened. Was the work done by a T dealer who should have the tools & know the procedure or was it a independent workshop who didn't so guessed?
When my h/stock bearing needed adjustment I wanted to order the tools from my dealer but they told me to take the bike in & they did for free!
« Last Edit: December 04, 2017, 10:19:33 AM by Will Morgan »
Offline Stillwobbling
  • Bike: Explorer 2012
  • City / Town: EastMids
« Reply #3 on: December 05, 2017, 03:54:28 PM »
I did mine this week as a matter of urgency when I found noticeable play in the bearings. I didn't have any special tools. A 38mm socket fits the top nut (or 1 1/2") just fine. Of course I'd rather have a dealer do it but I've been working on cars for 40 years and of course looked at You Toob for some hints. I couldn't leave it like that so had to tackle it. Only needed a nip. Made a huge difference to the steering. But mine was too loose not too tight. I have to say that if that was mine I'd be straight back round to the place that did the work in the first place. It needs to be right and there should be some resistance but it shouldn't drag. Worth checking of course that they've not trapped any cables or anything under the shroud.
Offline ijinak
  • City / Town: Alaska
« Reply #4 on: December 05, 2017, 04:26:40 PM »
I'd take it back and have them adjust it again. It should be smooth and easy to turn. Some heavy handed monkey with no torque wrench likely did it the first time :232:
Offline MarksMotorCycleParts
  • Forum Sponsor
  • Bike: 1200 Explorer
  • City / Town: Bath
« Reply #5 on: December 07, 2017, 01:15:38 PM »
Agree, somethings not right. Rather than have a look yourself just take it back.
Offline fubbytucker
« Reply #6 on: December 20, 2017, 09:08:21 AM »
Well I'm back at the independent garage that did it. I've been told that they will loosen off but I've asked them to readjust it and to use the triumph torque settings. They are doing great it now so we will see...
Offline fubbytucker
« Reply #7 on: December 20, 2017, 10:32:41 AM »
Massively improved.
Garage said it was because they pack their bearing with grease but that it should have eased off quickly.  Time will tell if it over loosens but I'm happy with it now.
Offline ijinak
« Reply #8 on: December 20, 2017, 07:10:04 PM »
Pack the bearing with grease? :151: Packed the mechanic with incompetence more like. I'm calling total BS on that one
Online oxidefilm
  • Bike: '13 Tex
  • City / Town: NYC
« Reply #9 on: December 20, 2017, 10:05:08 PM »
Yes. That's not what grease does.
