Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Gen 3 Brake Judder  (Read 4906 times)
Offline pcarnut
Re: Gen 3 Brake Judder
« Reply #20 on: November 08, 2018, 03:44:11 AM »
Never heard about this one!
And what is it supposed to do?
Helps get air out of the line, don't know the exact way it works but it does.  Wrap a small bungee or something elastic around the brake lever so it pull the lever towards the handlebar with light-moderate pressure, leave it over night.  It often helps firm up a spongy lever.  Just don't forget to take it off before trying to ride away!  :087:
Offline RaglandT
  • Bike: Tigers 800xc-1200XRT
  • City / Town: San Francisco
« Reply #21 on: November 08, 2018, 05:27:34 AM »
I think the theory behind the bungie cord trick is that pulling the lever opens the valve to the lines, and then leaving it overnight the air in the lines will rise up through the reservoir on the bar - exiting the lines ...
Offline unsubtle
« Reply #22 on: November 09, 2018, 12:53:00 PM »
Pulling the lever closes off the line from the reservoir. You can see this happening at the hole at the bottom of the reservoir if you take the top off.  It's more normal to leave the lever alone, turn the bars to put the reservoir as high as possible, and leave overnight to get air out of the line - but of course on a TEX that won't clear air in the loop over the front wheel.
If there is only a little air in the line, gently working the lever back and forth will often work faster, and you can see the bubbes coming up into the reservoir.
« Last Edit: November 09, 2018, 12:55:13 PM by unsubtle »
« Reply #23 on: November 09, 2018, 02:24:52 PM »
This is the procedure I know.
(which I performed on an old Aprilia recently)
Offline D16PJM
  • Bike: 1200 XRT 2018
  • City / Town: Sidcup
« Reply #24 on: November 13, 2019, 12:07:41 AM »
its an old post but had my bike 2 weeks and noticing that i have a pulsing on the brakes, dealer i bought it from is happy to repair but is 200 miles away, as the bike still has warranty i may just take to the local triumph dealer, hope this is not a sign of things to come
Pete
Offline Pailton
  • Bike: Tiger 1200 XRX
  • City / Town: Leicester
« Reply #25 on: November 21, 2019, 02:58:01 AM »
If the bikes still under 2 years old D16 any Triumph dealer will honour the warranty.
I've done a further 17k miles and all is well, the front wheel was the culprit.
Hope yours gets sorted easily mate.  :028:
Offline pcarnut
« Reply #26 on: November 21, 2019, 03:30:05 AM »
*Originally Posted by unsubtle [+]
Back and forth, as in pumping the lever?
