Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Immobiliser ECU, or main ECU?  (Read 716 times)
Offline Tigerman2012
  • Bike: Tiger Explorer 1200
  • City / Town: Essex
« on: June 20, 2018, 09:38:06 PM »
OK. Serviced the Tex (50k miles), put everything back together and went to fire up the throaty triple.  :152:
Lights flashed and needles swung as they should, immobiliser light came on, went off, then came on permanently!  :086: Result? Not a peep, squeak or groan from the starter circuit, and the Tex just stood there, all forlorn.  :114: I do not have an alarm fitted, just the OEM immobiliser.
Removed tank (again. Hate taking that off),  :013: and checked carefully everything was connected and tight, especially the Immobiliser ECU. Reassembled, and nada! Same thing happened.  :019:  :110:
Took it to a good dealer, who believed it was either the keys becoming unmapped, or the immobiliser ECU failed. He tried everything - mapping existing keys, mapping new keys, checking comms between the 2 ECU's, and the diagnostic check just kept stating 'no keys found'.  :084:
Didn't really want to leave it there for a few days, as they were really struggling to work out what it could be.
Saw a complete lock set with keys, and both ECU's from a breaking bike (2014 Tex), and purchased the same, hopefully this will cure the problem! :020:
Silly question - how to remove/replace the seat lock above the rear number plate? Can't see an obvious way to do this... :034:
If the throttle is not wide open, and the clutch not disengaged, I'm not doing it right...
Offline unsubtle
Re: Immobiliser ECU, or main ECU?
« Reply #1 on: June 22, 2018, 01:56:15 AM »
Just as a thought - one or two of us have had a wire break in the bundle going to the handlebars. It seems to be a little tight as standard. In my case the break caused an intermittent failure of the rear light, but the bundle also contains the wiring to the ring sensor around the keyway. If it's that, changing the keys and the ECU won't help. I would disconnected it at the block connector and check for continuity of that circuit. You might also get lucky and see a response by putting the key in and turned on, while waggling the bundle around.
« Reply #2 on: August 10, 2018, 07:08:04 PM »
Well, after much messing around, and Tex spending a few weeks at the dealer, they found that the transmitter loop had failed, although no physical evidence of this. All ECU's OK, but have to buy a new ignition switch (2nd one so far in it's 6 year life...).
