Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Fitting Givi Monokey rack to Tiger 1200 (ie gen3)  (Read 2155 times)
Online KenW
« on: July 02, 2018, 08:11:48 AM »
I was loathe to swap from my old Givi Monokey plastic panniers to flash new ones on my Tiger 1200.  They would cost heaps, and store less.
Well, pleased to say I've successfully fitted my Givi PLR6403 Monokey frames onto my T1200.
I bought a pair of second-hand gen1 pillion hangers from eBay and fitted them in place of the originals.  Cost me AU$50 including postage.
(Got the idea of doing this from https://www.tiger-explorer.com/index.php/topic,16611.0.html.)
They fit fine, onto the same fixings, and the footrests end up in the same place.  -My pillion reports no change.
I haven't painted them so far, and probably won't.  Viewers of my new bike don't notice the colour difference unless they saw the originals.  (And I'm lazy.)
I graunched (ie crudely adjusted) the long forward bottom bar of the right-hand carrier in a bit and down a bit, until the frame cleared the exhaust enough.
Without adjustment, it was riding on the exhaust hanger.
Now it has 1cm or more clearance.
Just letting you gen3 owners it can be done.  (I have an XRt, with the Arrow exhaust.)
Offline TPadden
  • Bike: Explorer 1200XC
  • City / Town: Brooksville Fl
Re: Fitting Givi Monokey rack to Tiger 1200 (ie gen3)
« Reply #1 on: July 02, 2018, 02:00:25 PM »
“This thread is worthless without pictures”  :031:
Online KenW
« Reply #2 on: July 03, 2018, 05:34:28 AM »
OK fusspots.  For a visual...
In the image below, you can see the unpainted gen1 pillion footpeg hangers, and the Givi rack fitted just like it would be on a gen1 TEx.
The rod at lower right had to be 'adjusted' so the rack was away from the exhaust.  (The left-hand rack went on unmodified.)
The unpainted hangers look OK to my eye.  There are a number of different colours on the bike, ranging from pure black, to the grey of the frame, to the chrome of the exhaust.  A bit of raw aluminium doesn't look too out of place among them.  -But then I'm not as fussy as some.
« Last Edit: July 03, 2018, 05:36:58 AM by kenw »
Offline TPadden
« Reply #3 on: July 03, 2018, 05:45:33 AM »
Looks good to me, nice work.
Tom
Offline BayAreaCelt
  • Bike: Tiger 1200 XCa
  • City / Town: SAN FRANCISCO
« Reply #4 on: July 18, 2018, 08:45:23 PM »
Top tip, if you buy genuine Triumph latch assembly T9500579 (thats the top box one) you can use the proper OEM luggage barrels you get when you buy the bike new.. also the latch is Triumph branded too, so on my Trekker Outback 58l box it looks properly nice!
Givi manufacture the OEM triumph stuff, so its 40 odd dollars in the US to be able to carry one less key around.. Win!
Offline Budweiserfrogie
  • Bike: Tiger 1200 XRT 2018
  • City / Town: Athlone
« Reply #5 on: July 19, 2018, 02:31:21 AM »
*Originally Posted by BayAreaCelt [+]
Here's all 3 part numbers for Left, Right & Top Triumph Latch assemblies in case any1 would like to use their Gen3 supplied luggage barrels on Givi Outback or Triumph Aluminium Luggage panniers.
I have my 3 Givi panniers fitted with Triumph branded latches and fitted the ignition matched barrels i got with my bike.
A9500690 Top box latch
T9500712 Left latch
T9500713 Right latch
(part numbers now updated)
Offline Fr.Mark
  • Bike: Khaki Gen 3 XRT 1200
  • City / Town: Cambridgeshire
« Reply #6 on: July 20, 2018, 11:30:38 AM »
Those numbers WILL NOT WORK with gen 3 bikes  :003: as the locks are of a larger diameter. Top box needs T9500690 not sure of panniers but dealer should be able to advise.
The secret of peace is not to avoid the rush and noise of the world but to live among the noise and rush and be calm yourself.
« Reply #7 on: July 20, 2018, 01:03:57 PM »
*Originally Posted by Fr.Mark [+]
Huge apologies.. i posted the latch part numbers for the 2017 bike.
I'll edit my post and correct the part numbers to the 2018 latch part numbers.
I have them on my 2018 XRT with the larger diameter provided locks fitted.
The 2018 part numbers as provided and ordered from www.worldoftriumph.com are:
T9500712 Left latch
« Last Edit: July 20, 2018, 01:13:54 PM by Budweiserfrogie »
Offline BayAreaCelt
« Reply #8 on: July 21, 2018, 12:10:53 AM »
Great to know, thanks for the clarification!
Online KenW
« Reply #9 on: August 17, 2018, 01:31:44 AM »
I have to add a bit to this thread.
I've noticed heat damage on my right hand pannier.  (Its a Givi Monokey 36L plastic pannier.)
This has probably come about because the rack's heat deflector was designed for the original TEx exhaust.
With the shorter Arrow exhaust on my T1200, evidently exhaust gas in front of the deflector is affecting the pannier.
The correct fix would be to add more deflector plate to the rack, forward of the existing one.
With me about to take off into the wild blue yonder, I'm taping a whole lot of aluminium tape over the affected area on the pannier.
Might look a bit silly, but too bad.
