Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: rox risers  (Read 656 times)
Offline bazthebike
  • Bike: xcx 17/blue
  • City / Town: southwest
  • Country: uk
rox risers
« on: September 18, 2018, 08:57:54 AM »
Hi all, can anyone tell me the length of the 4 handlebar clamp bolts on the rox risers. Recently bought kit here but the clamp bolts are two different lengths.Thank you.
Online oxidefilm
  • Bike: '13 Tex
  • City / Town: NYC
Re: rox risers
« Reply #1 on: September 18, 2018, 02:39:38 PM »
Pretty sure the long bolts are 110mm and the short bolts are stock length.
Offline Tigraid
  • Bike: '16 R1200GSA
  • City / Town: Dursley
Re: rox risers
« Reply #2 on: September 18, 2018, 04:03:35 PM »
The ones supplied with the Rox risers are correct.  One set need to be longer as you'll see when you remove your standard ones.  Be very careful when you install them to ensure that there is sufficient slack on all cables and hoses.  There is NO spare slack in the wiring loom nor the hydraulic hoses, so there's a high risk of over straining the loom if you have too much bar pull back with the risers in place.  You will probably need to discard the wired cable tidy behind the headstock as well. I had to when I installed mine.
Offline ijinak
  • City / Town: Alaska
Re: rox risers
« Reply #3 on: September 18, 2018, 05:07:01 PM »
I installed mine with no cable problems. The front and back bolts are different lengths. The access holes mean they can only be set in one position
Offline bazthebike
  • Bike: xcx 17/blue
  • Country: uk
Re: rox risers
« Reply #4 on: September 18, 2018, 05:45:55 PM »
Sorry to cause confusion here, but I mean the top clamp bolts, 4 off, two are 25mm and two are 30mm. the original triumph bolts are 90mm and 30mm.(that fit first.
Re: rox risers
« Reply #5 on: September 20, 2018, 04:51:29 PM »
*Originally Posted by bazthebike [+]
I don't recall mine being different lengths.
