Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Thoughts on Klim Badlands Pro or Rev'It Dominator  (Read 1208 times)
Offline TTruckie
  • XCa in 'fastest' White
  • Bike: Explorer XCa '16
  • City / Town: Swindon
« on: October 07, 2018, 09:07:01 PM »
As the title says...... I'm looking for new kit as I'm tied of getting wet (and I've been saving my pennies!).  I'd like the adventure style fully waterproof (without silly linings!) and with plenty of ventilation.
I've seen the Klim Badlands and the Revc'It Dominator both look similar in features etc.
Any one got any experience
TTruckie
Offline Hax
  • Bike: '19 XRX
  • Country: Aberdeenshire
Re: Thoughts on Klim Badlands Pro or Rev'It Dominator
« Reply #1 on: October 08, 2018, 06:53:22 AM »
The Klim stuff is nice but went for Rukka as I thought it was better put together. Give Jenks a shout (pm) on here for a comparison - top bloke.
https://www.tiger-explorer.com/index.php/topic,15795.msg192155.html#msg192155
Offline Ozlaw
  • Bike: Explorer XCA
  • City / Town: Cambridge
« Reply #2 on: October 08, 2018, 08:48:15 AM »
I’ve been using the Rev’It Dominator for the past 3.5 years and have to say it’s performed fantastically!
It has been comfy and entirely waterproof the entire time, and shows little signs of wear having been used constantly, year round in all weathers since.
I have washed it and ‘reproofed’ with Nikwax wash in stuff every so often, but only for cleaning rather than the need to waterproof.
It has plenty of ventilation and have worn it through 40 degree heat in the south of France. I had the original model, where the trousers don’t have vents, and when this set go (can’t see it happening any time soon) will replace with the newer revised version.
It doesn’t come with any thermal layers, as it’s deaigned to be used with layering system, but I use base layers for summer and winter, with heated clothing underneath for winter and it makes rides in near freezing temperatures a doddle.
The style is spot on for me. Lots of pockets, full zip between jacket and trousers adjustment straps for great fit, comfy armour and feels well protected with quality material.
I’d definitely recommend it!
Offline johnnybet
  • Bike: cb500x
  • City / Town: London
« Reply #3 on: October 08, 2018, 12:49:07 PM »
I have had the same issue when i was looking to get a good suit.
Finally i got the Siima Sibirsky suit.
Probably the most versatile suit i ve seen out there.
It has rain layer that's attached on top, and the jacket is transformed into a mesh jacket for the summer.
Pants also have a layer attached on top, thermal linen that's removable and front and back vents.
I believe i did the best choice for the money i paid.
Cheers!
Offline TTruckie
« Reply #4 on: October 08, 2018, 08:09:56 PM »
thanks gents, your comments are appreciated. :046:
TTruckie
Online Slaine
  • Bike: Explorer XCX
  • City / Town: Lippstadt
  • Country: Germany
« Reply #5 on: October 14, 2018, 09:17:33 PM »
Been using Dane Goretex Pro Jacket and Trousers for 5 Years, expensive but worth every penny
« Reply #6 on: October 14, 2018, 10:13:55 PM »
Both top notch laminate systems no doubt. As with all technologies other manufacturers push into the market and depress the pricing. Oxford now do a full featured laminate textile system for £249 Jacket and £199 pants, a very impressive price and definitely on my shopping list once my RST gear wears out (although that is holding up very nicely). Bennetts Bike did a little YouTube clip featuring the Oxford Laminate gear from the recent German bike fair, Intermot. Forward for 3:50 for the laminate range.
« Last Edit: October 14, 2018, 10:37:51 PM by XCaTel »
  • Bike: 2017 Explorer XRT
« Reply #7 on: November 04, 2018, 07:50:42 AM »
I have a Badlands Pro suit, and I love it.  It's the first "premium" suit I've ever owned.
I have only had it for six months or so, but here are my observations:
   1.  Absolutely windproof.  When zipped up, the cold air is not getting through.  Need to make sure you cuffs are snug though, or some air can get around your gauntlets.
    2.  Waterproof.  Just need to make sure your vents are closed all the way and the neck opening is cinched up, or water will get in there.
    3.  Heavy.  Not uncomfortable, just heavy.  Something to consider if you are going to be loading your bike up to the maximum.  With boots and helmet, I'm 25 pounds heavier in this suit.
    4.  So far, the coldest ride I have had in this suit  was this morning at 34F.  Legs were comfortable, not cold at all with just a thin base layer.  I had heated gear up top, so that was fine, too.   :002:  I have worn just the jacket in similar temps without the heated gear, and stayed warm enough for a short ride.
    5.  It gets hot above the low 80F range.  It breathes well, but if you're going slow or are stuck in traffic, it can get uncomfortable.
    6.   Depending on your riding style, the ventilation is OK to excellent.  Sitting down, it is just OK.  If you spend a lot of time standing on the pegs, you'll flow a ton of air.  Seems to flow more air if I don't have my tankbag on.
   7.  It's subjective I know.....but I really like the styling.  I have the Hi-viz.
Here are my negatives:
    1.  It has big and heavy, glove friendly YKK zippers all around- except for the one that joins the jacket to the pants.  I struggle with this zipper constantly.  I have not found a way to quickly and reliably get the two halves of this zipper to mate.  Once started, it works fine.  Needs a longer or heavier (or both) zipper to make this easier.  I also removed the kidney belt-  didn't need it and it interfered with zipping the top and bottom together; it just got in the way.
    2.  I found that if I put my 3 litre hydration pack in the jacket, the added weight would pull the front of the collar uncomfortably against my throat.  Might work better with a smaller pack, but I went back to using the backpack.
    3.  The handwarmer pockets are placed at an odd angle, and are kind of hard to open and close with gloves on.
    4.  The pants do not have full length zippers down the legs.  That's not a complaint, but you can't drop them as far down as you may like for certain calls of nature.
I would buy this suit again when I wear this one out.
Behold, the MaidenCruiser!
Offline TTruckie
« Reply #8 on: November 04, 2018, 08:12:16 PM »
Thanks JG for a great review
TTruckie
Offline TTruckie
« Reply #9 on: November 25, 2018, 11:04:55 AM »
just some feedback - i went for the Klim in the end  :152:
not allowed to wear them yet as Santa will deliver them :047:
I'll let you know how i got on but they look great.
TTruckie
