Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Uneven brake pad wear  (Read 1178 times)
Offline Rockhopp3r
  • Bike: TEX
  • City / Town: Los Angeles
« on: October 12, 2018, 05:16:56 AM »
This afternoon, while servicing my bike, I pulled the brake calipers to check the pads and discovered that the front right pads were wearing unevenly (see attached pic).
What can be causing this?
When I pulled the other two calipers, pad wear seemed even.
I just got this bike and I'm going through numerous items to ensure it continues to run smoothly. To address this, I've ordered new brake pads but I really don't want to have to buy them every 3K miles :P
Shot from above:
Interestingly, while I didn't find uneven wear on the left caliper, I did notice that both pads have a very similar crack in them. Any idea of what the cause could be?
« Last Edit: October 12, 2018, 05:18:40 AM by Rockhopp3r »
Re: Uneven brake pad wear
« Reply #1 on: October 12, 2018, 06:01:02 AM »
No idea on the cracking, but on the caliper where one pad has worn excessively, i’d first check whether the pistons on that side are sticking, possibly from a build up of crud - maybe make sure they run in and out smoothly.
« Reply #2 on: October 12, 2018, 04:04:52 PM »
*Originally Posted by Hawkeye [+]
:0461: Use a spray brake cleaner and a toothbrush to clean each piston. Gently work them in and out about a quarter of an inch (don't pop one out) and continue cleaning until they move easily.
Offline Rockhopp3r
  • Bike: TEX
« Reply #3 on: October 12, 2018, 04:19:13 PM »
Thanks. Too late not to pop one out. I accidentally popped one out by pumping the brakes with the pads off (don't ask me why I did that) so now I'm taking them apart and cleaning them.
Are these seals reusable?
« Reply #4 on: October 12, 2018, 05:01:33 PM »
*Originally Posted by Rockhopp3r [+]
I would tend to say yes if they are not damaged. How many miles on the bike?
Offline Rockhopp3r
  • Bike: TEX
« Reply #5 on: October 12, 2018, 05:04:55 PM »
22k.
The issue I have is that getting these seals might take a while. Don't know who stocks them in my area.
« Reply #6 on: October 12, 2018, 09:19:18 PM »
Its your own call on whether the seals can be reused. That said - I strip mine every year - totally clean and reassemble using existing seals. I keep a spare set of pads on the shelf to change whenever I'm getting a bit low - bike has nearly 30k on it and brakes are perfect.
Offline Rockhopp3r
  • Bike: TEX
« Reply #7 on: October 12, 2018, 10:02:54 PM »
So, brakes are completely disassembled now. Took the calipers to a shop to get out the seized pistons and fortunately they were able to do it. I didn't have the tools here to get it done and didn't want to mark the pistons with pliers.
Now, the most interesting issue is that, while I was there, I asked them to order sets of seals and a set for one caliper is going for $67!!!!  :005: :005: Both sets of seals would cost a staggering $134 plus shipping. Is this price normal? I sold my GSA in part because of higher maintenance costs. $134 for a set of seals for the front sounds incredibly high.
Where are you guys sourcing your seals from??
Online Simmo
  • Bike: 2017 1200 XRT White
« Reply #8 on: October 12, 2018, 10:46:36 PM »
Sounds steep to me! World of Triumph appears to be saying that a complete piston & seal kit is 31.80GBP per caliper!
I know it probably doesn't help but it gives a bit of a guide. Good luck
Simmo
Offline Rockhopp3r
  • Bike: TEX
« Reply #9 on: October 12, 2018, 10:54:24 PM »
I'm seeing 60 GBP for the piston and seal set at WoT. Price is per caliper. Comes out to a similar price in USD.
http://www.worldoftriumph.com/triumph_motorcycle_parts_locator?block_01=&block_02=100063183-0-2&block_03=560600
