Stuffed them in at lunchtime to day. Lovely modern white light. I did one side to compare. It was like a candle in the other side. Best to take the whole headlight assembly out. Tricky shoving all the gubbins inside the housing otherwise.
I rarely drive at night and the std lamps were pretty good but in terms of being noticed, these just look better and blend with the LED side mounted lamps too.
Thanks once again.
Just remember that before getting your Tex serviced, you'll need to take them out and replace them with the standard bulbs as the Keewors cause errors to show up on the software updates, and if the dealer can't clear the errors (which he can't when they are fitted), then your ECU/Chassis/Clock software can't be updated for patches and software updates (this includes the side light if you have replaced that with an LED bulb as well)
I had the Keewors in mine, but took them out in the end as to change them over was a pain in the butt each time it went in for service - instead I'm now running Osram Nightracers, which are just as good (IMO) - and don't throw up errors on the dealer software checks
