Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Error code P16A2  (Read 1417 times)
Error code P16A2
« on: December 29, 2018, 01:32:02 PM »
On my Gen 2 I recently had a message on the dash when I switch on the ignition but it went off instantly.....in fact so damn quick I couldn't read it!
There's nothing unusual showing on any dash warning lights or under "show warnings" on the menu.
So I checked for error codes and found P16A2 C0000. On the list I had saved from elsewhere on this forum all codes have a letter followed by 4 numbers and none has a letter in 4th position like the 'A' in this error code.
Anyone got any ideas what it is?
Re: Error code P16A2
« Reply #1 on: December 29, 2018, 04:00:08 PM »
Sorry, my posted DTC list on here is incomplete and I need to update it when I can find the time. However, I do have a complete list and...
P16A2  Engine ECM detects Inertial Measurement Unit (IMU) present but with signal error.
As a result, Cornering Traction Control and Roll-Over Detection are disabled. This fault won't illuminate the MIL but will take 40 no-fault cycles before it gets erased. Initial diagnostics are to check that the IMU connector is secure. After that, it's a case of carrying out a number of pinpoint tests between the ECM and IMU for short & open circuit conditions.
C0000 means that there are no Chassis ECM errors.
« Reply #2 on: December 29, 2018, 04:29:47 PM »
Top chap, thank you for such a precise explanation - and so quickly. It's help like this that makes this forum so invaluable!
So next question.....whereabouts is the IMU connector located?
« Last Edit: December 29, 2018, 04:33:22 PM by Will Morgan »
« Reply #3 on: December 29, 2018, 04:46:31 PM »
Under the seat bridge at the back end of the petrol tank.
« Reply #4 on: December 29, 2018, 07:05:41 PM »
Thanks again! I'll check it tomorrow.
« Reply #5 on: March 12, 2019, 02:43:13 PM »
After ignoring the error code  & riding as usual with no sign of anything amiss, I eventually got the dealer to investigate. First step was to clear the error to see if it would recur - pleased to report it hasn't.
Dealer reckons it was the canbus system or some sensor having a random hissy-fit. When they interrogated the system there were a few other errors recorded but none to cause concern & didn't tell me specifics of what they were.
Their best-guess diagnosis was they were all adverse reactions to low battery voltage.
I don't use a trickle charger 'coz the bike gets run often enough to keep volts good but dealer said it might be advisable as a precaution.
Offline salisburytiger
  • Bike: Tiger 1200XRt 2018
  • City / Town: Salisbury
« Reply #6 on: March 12, 2019, 05:56:24 PM »
Interesting that, seems having a battery which is not quite spot on causes bikes all sorts of trouble...
Cars don't have that issue do they?
I thought leaving my optimate connected most of the time was overkill but maybe not...
« Reply #7 on: March 12, 2019, 06:47:28 PM »
*Originally Posted by salisburytiger [+]
I am grateful for my gen1 TEX which has no such issues. Still on the original battery. I top up the charge once per winter and never leave it on trickle charge. And no issues, so far.
« Reply #8 on: March 12, 2019, 07:40:39 PM »
quite... I'm driving a computer with an engine!
(and it wants a good voltage!)
