Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Help! It won’t start!!!  (Read 1105 times)
Offline R.
  • Bike: XRX 1200
  • Country: Belgium
Re: Help! It won’t start!!!
« Reply #10 on: February 10, 2019, 05:46:29 PM »
when not driving for longer than a week I keep the battery connected to something like this  https://www.optimate.co.uk/products/optimate-4 (disclaimer , I do not have stock in this company).
I have to replace my battery on average every 5 years and have (knock on wood) never had any starting problems.
R.
Offline Lancstony
  • Bike: Tiger XCA
  • City / Town: Rossendale
« Reply #11 on: February 10, 2019, 06:32:33 PM »
Had the charger on and it’s started now so yep it was the battery 🤦🏻‍♂️ I’m such an idiot! Will see how it goes and if is a problem looks like will be a new battery, oh dear :-(
Offline Jarse
  • Bike: XC12/T120
  • City / Town: Aberdeen
« Reply #12 on: February 10, 2019, 09:20:26 PM »
All good then 👍🏻
As stated, an optimiser or similar is a good idea.
Offline Hax
  • Bike: '19 XRX
  • Country: Aberdeenshire
« Reply #13 on: February 11, 2019, 04:02:03 AM »
*Originally Posted by oxidefilm [+]
I'll pile on here-- The dash and lights require very little power. The starter requires a great deal of power. It sounds like you have a battery that needs charging. Try to jump it from a car and see if that works.
Caution! Watch what you’re doing jumping from another vehicle..
NEVER jump it from a running car. ECU’s and everything are really suseptical to power surges so from a low battery at say 10-11 volts jumped to a running car at 14.5volts then you run a high risk of frying the brains/immobiliser etc.
Static 12 volt good battery and you’ll be fine.
Offline bladerunner
  • Bike: explorer1215
  • City / Town: east kilbride
  • Country: scotland
« Reply #14 on: February 11, 2019, 07:16:25 PM »
I have the same sort of problem with my explorer. its been on a trickle charge all the time but when I pull the clutch and press start all I get is a click and nothing . Dash lights all on but wont start.  Eventually starts after pushing start button dozens of times. Any ideas anyone?
Offline Lancstony
  • Bike: Tiger XCA
« Reply #15 on: February 11, 2019, 08:45:46 PM »
I don’t know what that would be to be honest, I didn’t even recognise mine as a flat battery so I’m useless with this stuff! Good job I can ride a bike!
Don’t understand why it would start after a few presses on the button unless it’s a loose cable somewhere maybe?
Online kenw
« Reply #16 on: February 11, 2019, 10:31:25 PM »
*Originally Posted by bladerunner [+]
If it does start eventually, I don't reckon its the battery.  Seems unlikely to suddenly work after not working.
If there is always a click, it's not the starter button or wiring to it.
You seem to imply that the dash stays powered up while the button is pressed but it's not starting.  I reckon that makes it solenoid contacts or starter motor brushes, or a shonky lead/contact to the starter.  -Or something in the HT system.
Does rocking the bike against the engine before trying make any difference?
If you have a multimeter (and you should have), monitoring the battery voltage while trying to start it will rule in or out battery issues.  Fortunately the TEx battery is easy to get to -just take off the seat.
Offline bladerunner
  • Country: scotland
« Reply #17 on: February 12, 2019, 08:31:37 PM »
Rocking the bike makes no difference. I think Ill have to put it in to my local mechanic and have him look at it. Thanks all.
Offline R.
  • Bike: XRX 1200
  • Country: Belgium
« Reply #18 on: February 13, 2019, 05:55:08 PM »
What happens when you use jump start cables  (preferably connected to a running car , do not switch on contact on the bike before connecting the cables ) ?
Is it the same or does it start without any problems ?
R.
« Reply #19 on: February 13, 2019, 09:08:25 PM »
*Originally Posted by R. [+]
R.
Actually if you're going to jump it from a car it's preferable that they not be running...... many automobile alternators are capable of putting out way over 100 amps which is entirely too much for the motorcycles electrical system
