Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Engine cuts out when warm  (Read 410 times)
Offline Nojalllen
  • Bike: Triumph explorer
  • City / Town: Widnes
« on: February 12, 2019, 03:24:25 PM »
Can I please ask has anyone experienced there engine cutting out when really hot ??
2013 triumph tiger explorer 17500 miles
I’ve not had the chance to ride my bike over the last nine months but as the MOT is due I thought I’d dust off the cobwebs and give it a quick oil change. Once the oil change was complete I let the engine running whilst I give it a little wash but after it’s been running about 20 mins and fan had cut in and out a few time the engine stopped. Whilst attempting to restart I noticed there was no fuel pump cutting in. Another thing I noticed was that as the ignition is first switched on the clocked went through the cycle as normal but after a few seconds the gear indicator display when out.
Once the bike has been left to cool everything goes back to normal and starts as it should.
Has anyone had any similar issues please or even where would you recommend starting the diagnostics.
At first I thought it could be a data tool fault but the website says this model has no outstanding concerns.
Any help would be appreciated.
« Last Edit: February 12, 2019, 03:31:19 PM by Nojalllen »
Re: Engine cuts out when warm
« Reply #1 on: February 12, 2019, 05:41:38 PM »
You washed it. I'm thinking that you may have a loose earth (ground) connection. Check your battery connections (both ends) to see that they are clean and tight. Look for corrosion.
Offline Nojalllen
« Reply #2 on: March 06, 2019, 03:57:25 PM »
In case anyone else is having these strange issues this is now all fixed. The fault was down to a faulty Datatool s4 alarm which (after Loads phone call to data tool and my local dealer) was replaced under warranty and the bike is now running normally.
« Reply #3 on: March 06, 2019, 04:32:31 PM »
*Originally Posted by Nojalllen [+]
Datatool has been an issue for others as well, with weird electrical issues.
