Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Engine Management Malfunction  (Read 1267 times)
Re: Engine Management Malfunction
« Reply #10 on: March 17, 2019, 12:19:44 PM »
5V sensor supply malfunction sounds like a missing 5v reference and or ground at the sensors . If all 3 share the same 5v line you should be able to check it at any of them  to see if you have a reference voltage and a good ground .
someone with a wiring diagram should  be able to help you with which pins to check
otherwise just look for obviously damaged wires or pushed out pins in the connectors
Offline ydnar
  • Bike: 2013 Explorer
  • City / Town: Kearney, NE
« Reply #11 on: March 23, 2019, 08:09:22 PM »
 :001:OK. After reading everything I decided to start it up and warm it up a few times. I turned it around in the street and headed back in and the light went out. However the DTC code still shows up when I check them. Would it now be safe to clear this code. I just got the TigerTool software and an interface so I can do it. I think it should be OK but I wasn't sure how they handle those things internally. So I need one more professional opinion.
Online T800XC
« Reply #12 on: March 23, 2019, 08:31:52 PM »
Just do it. If the fault reoccurs it'll register again then might need more investigation.
Offline ydnar
« Reply #13 on: March 23, 2019, 08:34:57 PM »
 :001:Great! Thanks
Offline ToeCutter
  • Bike: Explorer XCx
  • City / Town: Newport
« Reply #14 on: March 24, 2019, 09:22:34 AM »
This thread is of particular interest to me, my TEX is currently residing in the garage in a large amount of pieces while awaiting for replacement shims to arrive.
It's the first time I've done this job on an explorer, but on other bikes if the management light comes up the first thing I do is clear any current faults and see what comes back. It can be very easy to go looking erroneous faults triggered by the service process.
I hope you get this sorted.
Offline ydnar
« Reply #15 on: March 26, 2019, 12:39:34 AM »
Thanks everybody I got all the errors figured out but found more thing in this comedy of errors. The timing chain now sounds noisy. I pulled the tensioner and it seems OK and I pulled the crank cover and nothing seems amiss. Could it be anything other than the tensioner? I haven't taken it out yet as the weather is still cool and lots of flood waters nearby. I guess that makes it a good time to work on it.
« Reply #16 on: March 26, 2019, 03:12:07 AM »
*Originally Posted by ydnar [+]
Did you follow the procedure to install the tensioner? You press the piston in until it locks, then install the tensioner, then back the crankshaft 1/4 turn (counter-clockwise), then turn the crankshaft forward 1/4 turn (clockwise). You should hear the tensioner release and that should set the correct cam chain tension.
« Reply #17 on: March 27, 2019, 08:20:08 PM »
all great advice - hope you get it sorted - good advice about clearing codes and setting the timing chain.  :002:
