Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Satnav bracket A9828022 for Zumo 395 ?  (Read 516 times)
Offline UNCLEBIGBAD
  • Bike: Explorer XCA
  • City / Town: Stafford
« on: March 22, 2019, 11:54:50 PM »
Hi folks - excuse the noob question (I've searched and can't find an answer).
Does anybody know if the Triumph satnav (part A9828022) bracket take a Zumo 395 bracket (see attachment)
TIA
Bigbad
Offline Collier32
  • Bike: 2016 explorer
  • City / Town: Burton on trent
Re: Satnav bracket A9828022 for Zumo 395 ?
« Reply #1 on: March 23, 2019, 08:07:00 AM »
yes the zumo mount does fit as I've just fitted mine  :152: :152:
Offline UNCLEBIGBAD
« Reply #2 on: March 23, 2019, 08:11:21 AM »
 :046: :046: :046: :046: yay - thanks Collier.  Where did you bring the power from - I want the cable out of sight (as in sitting in the groove on the underside of the bracket).....just wondering.
Cheers again
Offline Collier32
« Reply #3 on: March 23, 2019, 10:26:33 AM »
Connected straight to battery , fed the lead along the right side of the bike  and up through the clock housing and in the groove on the mount only thing I found was the transformer block sits right where the seat fits so I have to have seat on high setting, Im going to try extending the lead when I get around to it
  • Bike: 2017 Explorer XRT
« Reply #4 on: March 29, 2019, 10:31:14 AM »
I ran the wiring harness for my 595 around the back of the instrument cluster, then under the plastic that covers the wires, cables and hoses at the front of the frame.
Then under the tank and back to my fuse block.
I clipped off the cables I knew I wasn't going to use to make the routing easier.  I only kept the USB port (can't have too many of those) and the power leads.
Mount and harness cable.
I had to make an extension cord for my Denali driving light dimmer relay- I could only use the seat in the low position with the relay on top of the battery.
The the cable for the USB port from the GPS loops around the toolkit area.
« Last Edit: March 29, 2019, 11:35:58 AM by JG_XRT »
Behold, the MaidenCruiser!
Offline UNCLEBIGBAD
« Reply #5 on: April 12, 2019, 09:14:46 PM »
THANK YOU for the posts - bracket arrived and fitted no problem at all.  Biggest problem was getting the cable round the side of the fuel tank, but easily sussed over a mug of finest yorkshire !   Works a treat and much better viewing position.
Cheers again - help much appreciated. :152: :152: :152: :152:
