Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Need tips for putting the seal back when refitting camshaft cover  (Read 1327 times)
Offline coolhand
  • Bike: Explorer 1200 (2012)
  • City / Town: Laksevåg
  • Country: Norge
I have finished the valve clearance/adjust/cussing-n-swearing  :232:/camshaft timing-sequence.
Now I am struggling with the camshaft cover. I have manouvered it into place. The rubber gasket/seal is underneath it. The problem is: How do I fit the seal to the cover? there is a groove in the cover which the seal fits into, but it is not a snug fit - so everytime I wiggle the seal into place, it wiggles out another place. And the working place aaround the cover is very cramped, even for a guy with normal-size hands.
Of course, I will probably manage this sometime during the next hundred years, but still....
Anyone have any lifehacks or other hacks to make this process smoother? If not, I fear I will bang my head in the wall in frustration  :148:
For now, I will take a break from this..... hope to get some useful tips soon  :002:
Re: Need tips for putting the seal back when refitting camshaft cover
« Reply #1 on: March 31, 2019, 05:45:53 PM »
Try putting a thin layer of liquid gasket on the seal, fitting the gasket and letting it dry for a bit, before you try fitting the cover.
Offline coolhand
  • Country: Norge
« Reply #2 on: March 31, 2019, 06:08:11 PM »
Hmmm, yeah, that is a good idea.
That means removing the cover once again, but I think that'll do it.
Will go  get som liquid gasket tomorrow. Will report back here when I have nailed it   :001:
Offline coolhand
  • Country: Norge
« Reply #3 on: April 01, 2019, 05:43:16 PM »
*Originally Posted by ijinak [+]
Worked like a charm!
I used a hight-temperature silicone gasket (liquid gasket for temps from -50 - 300 C, that is intended for this kind of usage) bought from the local motor shop. Put on the silicon, waited 5 minutes, and then it was no problem fitting the cover!
Thanx!
« Reply #4 on: April 02, 2019, 10:01:13 PM »
Yep - good tip - I do the same - bit of grease can work too if your real careful. Well done - its pain removing everything again if there is a little weep so worth taking your time to sort it out first time !!
Offline ToeCutter
  • Bike: Explorer XCx
  • City / Town: Newport
« Reply #5 on: April 03, 2019, 09:33:27 AM »
*Originally Posted by eps [+]
Spot on,  the TEX has to be one of the most cramped and awkward bikes I've done maintenance on.
I just can't see how a main dealer can do a major service in a day ,  I'm a fitter by trade working on all sorts, big and small.
I reckon to go through the front end, back end and engine is best part of two days work.
« Reply #6 on: April 03, 2019, 05:29:31 PM »
*Originally Posted by ToeCutter [+]
Or a winter, if it was me.  :034:
Offline coolhand
  • Country: Norge
« Reply #7 on: April 05, 2019, 06:06:15 PM »
Just finished the bike today. I am a somewhat experienced hobby mechanic. I've done valve adjustment on a ZZR kwak, changed 2nd gear on a ZX9, and changed the cluctch on a Honda XX. I usually manage wuite fine.
The Tiger was no different, but hell it was cramped and akward to work sometimes. I asked my locla mehcanic about the valve adjustment: He told me they usually did not do them on 16000 km, but instead waited until 32000 km, just to save time. I would estimate a professional could do the job on two days minimum. They agreed.
Anyway, job done, I am happy! And the engine makes happy sounds! :046:
Offline ToeCutter
« Reply #8 on: April 05, 2019, 07:00:53 PM »
*Originally Posted by coolhand [+]
Good to hear,  I must say after having done mine it's a definite improvement,  that may in part be that even thought it's covered 16000km, all the exhaust clearances were tighter than spec by 0.025. also one intake was tight as well.
« Reply #9 on: April 05, 2019, 07:20:24 PM »
The official TEX service schedule was amended in 2013 to put the first valve clearance check at 32k kms rather than 16k. The one-time valve timing is also done then. I found that made a difference on my bike -- runs smoother.
