Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Coolant drainplug washer size  (Read 447 times)
Offline Solidsnake
  • Bike: Tiger Explorer XC
  • City / Town: Gällivare
  • Country: Sweden
« on: May 15, 2019, 11:19:52 PM »
Heeyoo
Does anyone know the measurements for the copperwasher on the coolant drainplug ? I've looked on this forum (not extensively, I admit) and on exploded diagrams but I can't seem to find the specs for this anywhere
I noticed last year when changing coolant that the washer is due for replacing so does anyone know what size I should go for ?
Re: Coolant drainplug washer size
« Reply #1 on: May 16, 2019, 08:27:17 AM »
Have a look at an online parts list. Dimensions of most nuts, bolts, washers etc. are shown:
https://www.fowlersparts.co.uk/browser/manufacturer/triumph/bike/tiger-1215-explorer-xrt-from-740277
Offline Solidsnake
  • Country: Sweden
« Reply #2 on: May 16, 2019, 12:29:40 PM »
Will do thank you!
Offline Solidsnake
  • Country: Sweden
« Reply #3 on: May 19, 2019, 08:20:58 PM »
unfortunately, no dimensions for the washer I need, not even an article number for it, but it's ok, I'll take the plug to a shop here that sells bolts, washers everything and figure it out from there
Offline KU55MCH
  • Bike: Tiger 1200 Explorer
  • City / Town: Southampton
« Reply #4 on: June 28, 2019, 04:21:14 PM »
I’m currently doing some work on my mate’s Explorer including flushing the coolant. Most sources say that coolant swapping is main dealer only. The most I’ve managed to find out after two hours research is the lowest drain bolt is on the left hand side but I can’t seen anything resembling a drain bolt with a copper washer.
Checked the parts list above. 👍🏻
Anybody point me in the right direction?
« Reply #5 on: June 28, 2019, 04:26:22 PM »
The engine block coolant drain is located on the left front corner of the cylinder block, above the radiator bracket and below the exhaust header pipe.
Offline KU55MCH
« Reply #6 on: June 28, 2019, 04:32:35 PM »
Wicked. Thanks. I was looking lower. Don’t know why when I think about it. 👍🏻
