Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: TSAS calibration problem  (Read 427 times)
Offline Karel
  • Bike: Tiger 1050 SE
  • City / Town: Utrecht
  • Country: Nederland
« on: May 22, 2019, 06:04:41 PM »
Hello my name is Karel and I’m the Dutch owner of a 2016 XRX Explorer.
The last year occasionally the TSAS system start calibrating after switching on ignition.
This is not a big problem when calibration goes well, but sometimes calibration will not finish.
The TSAS warning light remains flashing and the system is not working any more.
According to the manual calibration only should occur after power interruption or after TSAS alarm.
Does anyone recognises this problem?
Best regards Karel
Offline bazthebike
  • Bike: xcx 17/blue
  • City / Town: southwest
  • Country: uk
Re: TSAS calibration problem
« Reply #1 on: May 22, 2019, 06:45:29 PM »
mine is gen2 xcx 2017 and occationally when I start its re calibrating. seems to take a while.
Offline TotnesSteve
  • Bike: Explorer Xrx
  • City / Town: Totnes
  • Country: U.K.
« Reply #2 on: May 22, 2019, 08:20:15 PM »
When the power from the battery falls below a certain threshold, the system re-initialises and therefore recalibrates. So suggest you check your battery.
If not now, when?
« Reply #3 on: May 23, 2019, 08:53:51 AM »
Good advices so far. Firstly, let the calibration process finish properly (it can take up to several minutes!), then check your battery, if all else fails take the bike at the dealer.
On a side note, it seems more and more newcomers forget to introduce themselves in the appropriate forum section, is it me or what?
« Reply #4 on: May 23, 2019, 11:07:01 AM »
*Originally Posted by TotnesSteve [+]
I had a TSAS error code (see: https://www.tiger-explorer.com/index.php/topic,17966.msg214221.html#msg214221)
The system must be hyper-sensitive to low battery. I had absolutely no other electrical or electronic problems and the battery was OK but somehow it still triggered the error code. TSAS continued to work correctly but I had to get dealer to clear the error code. The problem hasn't recurred even without using a trickle charger as dealer suggested.
Offline bazthebike
  • Bike: xcx 17/blue
  • Country: uk
« Reply #5 on: May 23, 2019, 01:29:31 PM »
Mine did the recalibration when starting on sunday. been in garage till Thursday, put battery charger on and within 5 minutes says battery fully charged. I don't think its a below par battery issue somehow. PS I don't use optimate. ( this was when I noticed flat rear tyre,).Damn. going away on it next week so bit panicky getting new tyre fitted. Had nail through middle and only bout 1.6mm left, so new one going on.
Offline Karel
« Reply #6 on: May 25, 2019, 02:26:14 PM »
Thanks for the response so far.
I decided to bring the bike to the dealer yesterday.
They couldn't find the cause. There were no error messages logged.
New software has been loaded. I hope this will solve the problem.
