Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Shad top box  (Read 1013 times)
Offline gibboian
  • Bike: TEX 1200 2012
  • City / Town: Warrington
Re: Shad top box
« Reply #10 on: September 05, 2019, 09:22:11 PM »
Its hard to explain the problem with the SHAD plate.
Basically you cant use the front half of the plate (that's where the front of the box clips in) if you bolt the plate to the front 2 rack fixings then the box is half on the pillion seat.
You have to make an adjusting plate as previously described. Acrylic is a great material for this as you can mark the places for the holes so easy. I will post a picture of my (not very elegant ) solution.
10mm acrylic is not easy to cut, its "self healing".
Re: Shad top box
« Reply #11 on: September 06, 2019, 10:21:40 AM »
*Originally Posted by gibboian [+]
A Dremel cutting disk at lowest speed should do the trick.
