Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Fuel range  (Read 856 times)
Offline AllanV
  • Bike: Triumph tiger xca
  • City / Town: Boksburg
  • Country: South Africa
Fuel range
« on: September 11, 2019, 03:22:49 PM »
Hi is there any reason why I don't get the correct range when I reset my fuel range?
Re: Fuel range
« Reply #1 on: September 11, 2019, 03:27:38 PM »
Fuel range is based on historical riding. So if you were driving like a madman before fueling up the range can be showing as much lower on your full tank. If you were driving sedately before fuelling up the opposite is true. You can actually find your range increasing after a fill up as you go along in the first scenario. How long that historical measurement period is over I don't know though.
Offline AllanV
Re: Fuel range
« Reply #2 on: September 11, 2019, 03:39:42 PM »
Yes I've seen that it's just like when I have a full tank I ride on the freeway. Set my cruise control on and Ride at a constant speed with low fuel consumption, I reset with the joystick but still only show max range 280km
Re: Fuel range
« Reply #3 on: September 11, 2019, 03:53:53 PM »
I’ve seen my Gen1’s range increase as I go from wild to mild. I think the calculations are based on “current” riding behavior. Current meaning the past few seconds.
Re: Fuel range
« Reply #4 on: September 11, 2019, 05:09:42 PM »
Confirmed (I play a lot with fuel figures ;-).
Re: Fuel range
« Reply #5 on: September 12, 2019, 09:08:41 AM »
*Originally Posted by AllanV [+]
Then after a rest it must default to a particular programmed value, relative to the float sender, to be updated as you ride.
Offline Xtof
  • Bike: Explorer Xrt '19
  • City / Town: Antwerpen
  • Country: BE
Re: Fuel range
« Reply #6 on: September 12, 2019, 12:22:35 PM »
Seems to be working pretty fine on a gen3 here.
Recalculates rather correctly after fuelling up, and driving for maybe 100 - 200 m.
Calculation seems to be based on recent driving, as it increases or decreases with my heartbeat and riding style :D
Offline eps
  • Bike: 2012 Tiger 1200
Re: Fuel range
« Reply #7 on: September 12, 2019, 08:51:44 PM »
Drove up the Col Du Tourmalet in May this year - nearly ran out of fuel on the way up - so much so that I switched engine off and coasted for around  8 miles at speeds up to 60mph on the way down the other side. When I refuelled it estimated a range of 515miles !!  :001: :001:
Dropped lie a stone of course when I pushed on a bit but never saw that sort of figure before !!
Re: Fuel range
« Reply #8 on: September 15, 2019, 06:03:59 PM »
I find that the fuel range tends to be realistic after refueling, then it gets optimistic in mid-range, then pessimistic when the low fuel light comes on.
