Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Cruise control Problem  (Read 601 times)
Offline mikerbull007
  • Bike: 2012 explorer
  • City / Town: Leicester
  • Country: Uk
« on: December 02, 2019, 10:06:33 PM »
Hi All.
Had an ABS problem recently as a result of riding through a deep flood. After drying and cleaning the sensor all was well. Managed to clear the logged fault with my Datatool software. Unfortunately it seems to have upset my Cruise Control which now no longer works.
Having searched the forum I have found the following:-
Ignition key ON engine not running
Cruise control OFF,
Activate front brake switch,
Rear brake switch,
Clutch switch,
Twist grip switch (throttle in the closed position)
Activate cruise ON/Off switch,
cruise accelerate switch,
cruise decelerate switch,
if the CC light goes out the CC is reset
Unfortunately this hasn't worked for me.
I wondered if anyone had any further ideas about resetting it.
My datatool software doesn't register that there is a problem with it but clearly there is as it wont turn on.
Had the bike from new in 2012 and now done 62K miles and never once had an issue with the cruise control before.
Regards, Mike
Re: Cruise control Problem
« Reply #1 on: December 03, 2019, 09:07:02 AM »
Nope, this is the only known CC reset procedure.
However, considering its complexity, I should add that I had to repeat it once or twice to get the CC back in nominal condition.
  • Country: Uk
« Reply #2 on: December 03, 2019, 01:59:36 PM »
Nik, many thanks for your comment.
I was obviously not doing it correctly as its now worked.
Regards, Mike
