Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: TPMS  (Read 709 times)
Offline held006
  • Bike: explorer 1200
  • City / Town: Ohio
TPMS
« on: March 16, 2020, 11:56:41 PM »
New to the forum. 1st time
triumph owner. I bought a 2013
explorer and ride DS in NE Ohio. Had a new set of tires installed and now the rear tire sensor doesn't record. Dealer is telling me that sensors go bad all the time and I should have had him put in a new one before he did the job. It worked fine before he changed the tire. Any thoughts.
Re: TPMS
« Reply #1 on: March 17, 2020, 12:32:06 AM »
 :400: to the family, held006. I can't help with the TPMS question since I don't have them but I'm sure someone else will chime in. I do know there have been a lot of questions on battery replacement on bikes up through 14-15 models, so perhaps they are still the original batteries and one just bit the dust. It happens...
Offline oxidefilm
  • Bike: '13 Tex
  • City / Town: NYC
Re: TPMS
« Reply #2 on: March 17, 2020, 01:01:04 AM »
Dealer may have broken it, forgotten to reinstall it or (least likely) it actually just stopped working after the tire install.
It's absurdly easy to replace the battery. Can't believe triumph requires a replacement of the unit. Just like the heated grips.
Online T800XC
Re: TPMS
« Reply #3 on: March 17, 2020, 01:12:58 PM »
Sounds like too much of a coincidence that it stopped working after the new tyre was fitted. TPMS batteries tend to give you upto a few years of warnings that they're getting low.
The TPMS instructions say they should be mounted facing a certain direction, so maybe yours got moved, but even then I'm not sure how much difference that makes
 I've put mine in a cordless drill before to test them!
Offline thumper
  • Bike: '18 XRt
  • City / Town: California
Re: TPMS
« Reply #4 on: March 17, 2020, 03:55:48 PM »
I had TPMS on my '13 Explorer, and I have TPMS on my '18 XRt.
I've had many tire changes at the dealership, and never had them not working when I got the bike back.
 :110:
ATGATT--Because if you crash, the world is your belt sander.
Re: TPMS
« Reply #5 on: March 17, 2020, 05:01:14 PM »
*Originally Posted by held006 [+]
Careless dealers frequently destroy TPMS sensors when changing tires. I imagine that they are not motivated to admit it and pay for the replacement themselves.
Offline sirsidneyrd
  • Bike: X12-Laverda Jota
  • City / Town: Cotswolds
Re: TPMS
« Reply #6 on: March 18, 2020, 10:28:16 AM »
Dealer should replace - it would say low battery if that was the case - earlier sensors could be taken apart and new batteries soldered in - then they became fully sealed units and are very expensive - there are some accessory makes available but. Iced to have it part of the interface - possibly someone could replace the later batteries - others will need to comment
Offline arkyleo
  • Bike: 2015 TEX
  • City / Town: N.Central Ar.
Re: TPMS
« Reply #7 on: March 19, 2020, 02:42:24 PM »
My 2015 TEX did not have a TPMS and I was feeling sad because I thought it would be a very useful accessory.  I ordered an aftermarket SYKIK from Amazon for about $58 and promptly sent it back for a refund.  Digits too faint to read in day light, erratic operation and vague instructions.  This one was bike specific with only 2 valve cap sensors (which let out 1# of air when you screw them on).. Save your $$$ :021:
2015 Tiger 1200
2008 Suzuki DR 650
2004 Harley 1200 Roadster
Offline Chippy4467
Re: TPMS
« Reply #8 on: March 19, 2020, 04:19:37 PM »
My Gen2 XRT has TPMS and rear didn't work after first tyre change (tyre specialist not Triumph dealer).  None in stock at local Triumph dealer and I was off on Tour to France 2 days later.  They ordered one and fitted on my return (£110 part ! ) plus they then had to pay triumph dealer to "link it" to the bike. Suspect they didn't make any profit on that rear tyre !
When they took tyre off to replace it the sensor was in bits rolling around inside tyre.
Suggest you ask dealer to remove tyre with you witnessing to see if sensor is physically damaged.  If it is then its their fault.
best of luck
Oh & welcome
« Last Edit: March 19, 2020, 04:21:10 PM by Chippy4467 »
Chippy
Offline held006
  • City / Town: Ohio
Re: TPMS
« Reply #9 on: March 23, 2020, 08:55:54 PM »
Thanks for everybodies input. I spoke w a Triumph dealer. He can program the TPMS off since it was installed as an option. Riding offroad, I do fiddle with TP and the low tire pressure code is annoying. This bike is great o/w and handles well for as big as it is. Steve
