Author Topic: Fork seals  (Read 439 times)
Offline pmckinnon
  • High Country ride
  • Bike: EXP 2012 Blue
  • City / Town: Sunbury
Fork seals
on: July 07, 2020, 12:17:02 PM
Hi all i have a 2012 model and im always blowing the oem fork seals, can someone give me the Skf seal codes to suit this bike as im over the standard crap.
Online Will Morgan
Re: Fork seals
Reply #1 on: July 07, 2020, 02:25:34 PM
Might be worth investigating further if your seals repeatedly fail.
My 2013 Gen 1 had fork seals fail because the bushes in the forks were not made to the correct tolerance (Triumph had been supplied with a bad batch & mine were replaced under warranty).
The loose fit meant there was lateral play so the fork legs didn't run straight & smooth in the seals = seals failed to keep oil in!
And maybe the same could happen if the bushes are badly worn?
Online Crosshairs
Re: Fork seals
Reply #2 on: July 07, 2020, 04:54:46 PM
You can get the seals here
https://shop.touratech.com/skf-fork-seal-dust-cover-kyb-46-suitable-for-triumph-explorer-from-2012.html
but if you have multiple failures I suspect you have other problems
Offline Freddy58
Re: Fork seals
Reply #3 on: July 07, 2020, 06:01:37 PM
There are 2 part numbers for the SKF seals... they are listed as the ones for KYB 46mm forks. They come in two colors, green and black.
SKF-KITG-46K (this is the green one)
SKF-KITB-46K (this is the black one)
There are usually lots of the green ones on ebay.
Offline pmckinnon
  • High Country ride
Re: Fork seals
Reply #4 on: July 08, 2020, 11:27:04 AM
Thanks for your replies, i will be checking the bushes when i pull it apart, i also think as i do a lot of dirt tracks the oil gets hot and expands excessively, so thinking filling with a little less oil
Offline Hawk281
  • Bike: tiger 1200 2018
Re: Fork seals
Reply #5 on: July 08, 2020, 04:51:20 PM
Do not reduce the amount of oil in your forks, this has a direct effect on dampening and function of the suspension. Very bad idea! :005:
