Author Topic: Front Brake Issue  (Read 3886 times)
#10
Offline MarksMotorCycleParts
  • Forum Sponsor
  • Bike: 1200 Explorer
  • City / Town: Bath
Re: Front Brake Issue
Reply #10 on: October 13, 2020, 09:08:32 AM
Don't push the pistons back in, with or without the pads fitted, until you have cleaned the caliper, paying attention to the pistons. Remove the caliper and pads and clean it all up with a toothbrush and some soapy water. Pushing the pistons back in before a clean is a good way to score the pistons and/or damage the seals, especially if they are currently jammed up with something. Have a torque wrench handy for the caliper bolts for reassembly.
  :467:
Remove calipers, & clean everything as much as you can before pushing the pistons back so you don't force dirt past the seals.
#11
Offline andrewr138
  • Bike: 2015 TEx XC
  • City / Town: Denver
Reply #11 on: October 13, 2020, 09:47:50 AM
Cleaned everything. Put it all back together and still have the pads rubbing still. Bled the brakes, cleaned the piston at the master cylinder. I’m out of ideas :(
#12
Offline Hax
  • Bike: '19 XRX
  • City / Town: Aberdeenshire
Reply #12 on: October 13, 2020, 11:21:19 AM
*Originally Posted by andrewr138 [+]
Pistons slide back into the caliper freely?  :084:
#13
Offline andrewr138
  • Bike: 2015 TEx XC
Reply #13 on: October 13, 2020, 01:18:32 PM
Yes. Able to push them in by hand.
#14
Offline Hax
  • Bike: '19 XRX
Reply #14 on: October 13, 2020, 03:31:16 PM
With the pads out of both calipers does the wheel spin free?
It's not a wheel bearing issue is it?  :027:
#15
Offline andrewr138
  • Bike: 2015 TEx XC
Reply #15 on: October 13, 2020, 04:19:47 PM
Spun like it should without the pads on.
#16
Reply #16 on: October 13, 2020, 04:43:32 PM
The inner seals should be pulling the pistons back in after your release the lever. With the pads in, are they just staying out after operating the brake lever? If so the inner seals could be shot. Sounds like the next step is to refurb the calipers. A seal kit is very cheap, pistons if required are a little dearer.
#17
Offline andrewr138
  • Bike: 2015 TEx XC
Reply #17 on: October 13, 2020, 04:53:59 PM
Everything looks like it should. Even a more experienced friend looked at it, and couldn’t figure it out. I’m unfortunately going to call the dealer in a little bit.
#18
Reply #18 on: October 13, 2020, 05:08:07 PM
I wonder has one of the discs taken a hit and bent the mounts and tilted it ever so slightly, good luck at the dealer.
#19
Offline andrewr138
  • Bike: 2015 TEx XC
Reply #19 on: October 13, 2020, 05:11:02 PM
The tire took a hit and that’s when all of this started. One dealer can’t look at it for 11 days. Trying to get in touch with the other now.
