Author Topic: Fuel line and pump power ext.  (Read 1205 times)
Offline Stablemate
  • Bike: 2013 Tiger Explorer
  • City / Town: Cape Coral, Fl.
on: December 02, 2020, 12:44:54 AM
I'm looking for suggestions to remotely connect the gas tank so I can run the bike and adjust the throttle bodies. I already have the Tiger Tool.
Stablemate
Re: Fuel line and pump power ext.
Reply #1 on: December 02, 2020, 06:43:05 AM
*Originally Posted by Stablemate [+]
Triumph sells the necessary tools:
Fuel line extension kit:   T3880001
Extension cable kit:   T3880123
I THINK that these are the correct parts, as seen on page 1.28 of my gen1 Explorer Service Manual
Offline Stablemate
Reply #2 on: December 02, 2020, 02:46:59 PM
Thanks, I was hoping some one else had them.
Stablemate
Reply #3 on: December 02, 2020, 04:23:13 PM
There was someone producing a kit for a while but he dropped it because there was little demand for it.
Offline ijinak
  • City / Town: Alaska
Reply #4 on: December 02, 2020, 07:17:18 PM
I just sold a set of these. The cable is cheap ($25-$30  I think) and you can make your own fuel line with hose from a DIY store and a couple of hose clamps
Reply #5 on: December 02, 2020, 07:19:02 PM
*Originally Posted by ijinak [+]
I figured you must have had a set.  :001:
Offline Stablemate
Reply #6 on: December 04, 2020, 09:57:40 PM
Thanks guys, ordered the power ext. from my dealer and found the fuel fittings & hose on Amazon.
Stablemate
Offline bigjim56
  • Bike: 2015 Explorer XC
  • City / Town: Hubbard/OH
Reply #7 on: December 05, 2020, 09:51:13 AM
If your your hose fittings are successful could you share a link for the fittings used? Thanks you.
Offline ijinak
Reply #8 on: December 05, 2020, 05:48:32 PM
You'll also need something to block off the 3 balance pipe outlets. I used a short length of fuel hose with a bit of metal rod jammed in one end
Offline pcarnut
  • City / Town: Carlsbad
Reply #9 on: January 05, 2021, 10:39:16 PM
FYI, you can simpley reverse the fuel tank and sit it on the seat frame rails.  I put a towel under mine so nothing gets scratch.  All the connections will reach and work, including the fuel line.  I've usually got about a gallon or so in the tank to make it manageable, a couple of bungees keep things steady.
2018 T12, 2014 TEx, 2011 1050
