Author Topic: 2001 Tiger 955i Roulette Green 48K - $4900  (Read 349 times)
Offline FL-Tig-Rider
  • Tiger Owner since 2001
  • Bike: Tiger 1200 XRT 2018
  • City / Town: Central Florida
on: September 15, 2021, 06:07:24 PM
2001 Triumph Tiger 955i For Sale
Picture M046
GENERAL INFORMATION:
•   955cc fuel injected 3-cylinder engine has a unique sound
•   104 HP, 68 ft-lbf of torque
•   6-speed manual transmission
•   48,700 miles, these Tigers easily run to 100K
•   Roulette Green Paint
•   9.1 inches of front wheel travel, 7.9 in rear
•   After 20 years, this bike still looks nearly new (that’s why I bought another Tiger!)
•   42-45 mpg average with mix of city/highway riding
•   Large 6.35 gallon fuel tank gives 240 mile range
•   Clean and clear Florida USA title, currently registered and ridden weekly
•   Needs nothing, just hop on and ride!  Everything works and it runs great.
ACCESSORIES:
•   TRIUMPH OEM Center-stand
•   TRIUMPH OEM 3-piece quick-detach matching hard case set (all keyed alike)
•   TRIUMPH OEM Front fender extension
•   Upgraded to LED brake/tail and turn signals
•   KISAN self-canceling turn signal relay with running light option and programmable flash time
•   TOURATECH crashbars for good protection of tank and engine
•   TRIUMPH highway pegs (OEM passenger pegs with custom mounting brackets)
•   LED  auxiliary lights (with dual bulbs; marker/driving)
•   ANSWER handlebars with original Triumph bar ends fitted
•   BARSNAKE installed in handlebars (cuts down on vibration)
•   MOOSE RACING crossbar pad (matches roulette green perfectly)
•   VISTA-CRUISE throttle lock
•   KURYAKYN throttle boss (twist grip assist)
•   CEE BAILEY’S #2 +6/+6 windscreen (with custom mounting to angle screen forward about 2” at the top edge; I tested a lot to get smooth air)
•   TYPE-S compass
•   GYB “Stopper” extra brake light
•   DAYSTAR rubber fork boots (to replace those hideous OEM units)
•   RIDETEAMTRIUMPH steel fuel fittings (replaced plastic OEM versions)
CUSTOM MADE ACCESSORIES:
•   Extra 12V power connections at steering head for GPS and another for tankbag
•   Helmet lock on hard case latch (locks helmet D-ring when case latch is locked)
•   Front cockpit fairing stiffener (required for larger screen)
•   2” Mirror extensions
•   Installed Voltmeter/Thermometer/Clock module directly above idiot lights on dash (really cool unit; dual temp sensing; ice warning; backlit; will also serve as sun visor for idiot lights, shows voltage even with ignition off)
SERVICE RELATED:
•   Major 48K service performed (at 46201 miles)
  o   Valve clearance check
  o   New spark plugs
  o   Air filter cleaned (K&N high performance, washable)
  o   New fuel filter
  o   New coolant
  o   New fork oil
•   Oil/filter change (at 48102 miles)
•   New gold O-ring chain and sprocket (at 47249 miles)
•   See pictures for tire tread (normally get 18K miles from front, 12K from rear)
•   Brake pads at 40% life remaining
•   Front and Rear brake fluid flush (at 45801 miles)
•   New Yuasa HP battery 09/2020 (normally get 3 year life in FL)
•   Uprated stator and voltage regulator installed in 2017
•   Factory tool kit and Owner’s Manual included
WHAT’s WRONG WITH IT?
•   Tiger stripe decals are bubbled up.
•   About 4 minor scratches from 50K miles of use
•   Charging system from factory does not provide much extra power for big accessories like heated gear.
Picture M045
Picture M047
Picture M048
Picture M049
Picture M050
Picture M051
Picture M052
Picture M053
Picture M054
Picture M055
Picture M056
Picture M057
Picture M058
Picture M059
Picture M060
Picture M061
Picture M062
Picture M063
Picture M064
75,000 miles in a Tiger saddle and counting!
My Intro Post
My 2001 Tiger 955i For Sale
Re: 2001 Tiger 955i Roulette Green 48K - $4900
Reply #1 on: September 15, 2021, 10:35:31 PM
That is an extremely clean example FL-Tig-Rider  :047:
Reply #2 on: September 16, 2021, 11:53:55 AM
Thanks.  I'm glad you think so because I'm asking the bluebook "excellent' price!  It's been a great bike and I really hate to see this old friend go, but I fear it will start getting neglected once I start riding my 2018 more and more.
That's what happened with my '97 Tiger after I bought my '01...  I kept it 4 years longer than I should have, thinking it was worth more to me keeping it rather than part with it for the minuscule amount it was worth.  I was wrong then and this one will hopefully be enjoyed by someone else soon.
My Intro Post
