Author Topic: Shifter adjustment - help needed  (Read 992 times)
Offline Guy YMX
  • Bike: Tiger 1200 2022
  • City / Town: Laval
on: May 20, 2022, 12:21:07 PM
I'm not familliar with a quick shifter and that configuration.
Is there any tips you can give me? I was thinking of adjusting the rod lenght, but there seem to be some wire attached with a clip, I don't want to break anything on it's first day :006:
Re: Shifter adjustment - help needed
Reply #1 on: May 20, 2022, 04:29:57 PM
I don't get it. Why would you want to tweak the QS? Mine's been perfect since day 1.
Offline Alahdamit
  • Bike: Tiger 1200 GT PRO
  • City / Town: Newton Abbot
Reply #2 on: May 20, 2022, 04:49:35 PM
I altered mine as my foot angle caused isses changing gear.
Use this site https://www.triumphinstructions.com/default.aspx
Enter the Quick shifter parn number, a9770199
I did mine without removing the footpeg, cooling header.
If you struggle with the bottom clip, use a magnet to get it back in.
Took me about 15 mins
Last Edit: May 20, 2022, 04:54:50 PM by Alahdamit
Offline Guy YMX
Reply #3 on: May 20, 2022, 08:49:34 PM
I don't want to tweak the QF, I want to slightly raise the shifter to allow easier shifting with my riding boots
Offline Guy YMX
Reply #4 on: May 20, 2022, 08:53:06 PM
*Originally Posted by Alahdamit [+]
Thanks, that's exactly what I was looking for  :467:
Reply #5 on: May 23, 2022, 12:17:35 PM
*Originally Posted by Guy YMX [+]
Adjusting the shifting lever then? I get it now ;-)
Offline Guy YMX
Reply #6 on: May 24, 2022, 02:02:12 AM
Shifter adjustment was a real PIA but I managed to get it done, thanks for all your help!
Offline Ninja
  • Bike: Ninja 1000 SX
  • City / Town: Whiterock
Reply #7 on: June 25, 2022, 05:55:38 PM
How did this work out in the end,,,, I may, reluctantly, have to do an adjustment as my ADV boots don't manage the up shifts very well so the current procedure of only wearing my street boots is not a solution,,.
I don't want to upset the quick shifter which is absolutely perfect?
Offline CraptainC
  • Bike: Gen3 XCa
  • City / Town: Chester
Reply #8 on: June 25, 2022, 10:58:08 PM
Hello All...
as an alternative you might want to consider fitting Pivot Pegz. I fitted these to my XCA a while back, and the definitely make operating of the gear change and rear brake levers a lot easier with both my street boots and Adv boots.
Check out https://pivotpegz.com/collections/triumph
CC
