Author Shifter adjustment - help needed  (Read 2207 times)
  • Offline Guy YMX   ca
    • Explorer Pro  ‐    162
    Offline Guy YMX
    • Bike: Tiger 1200RP 2023
    • City / Town: Laval
    on: May 20, 2022, 12:21:07 pm
    I'm not familliar with a quick shifter and that configuration.
    Is there any tips you can give me? I was thinking of adjusting the rod lenght, but there seem to be some wire attached with a clip, I don't want to break anything on it's first day :006:
  • Offline NiK   fr
    • Explorer God  ‐    5091
    Re: Shifter adjustment - help needed
    Reply #1 on: May 20, 2022, 04:29:57 pm
    I don't get it. Why would you want to tweak the QS? Mine's been perfect since day 1.
  • Offline Alahdamit   gb
    • Explorer Member  ‐    23
    Offline Alahdamit
    • Bike: Tiger 1200 GT PRO
    • City / Town: Newton Abbot
    Reply #2 on: May 20, 2022, 04:49:35 pm
    I altered mine as my foot angle caused isses changing gear.
    Use this site https://www.triumphinstructions.com/default.aspx
    Enter the Quick shifter parn number, a9770199
    I did mine without removing the footpeg, cooling header.
    If you struggle with the bottom clip, use a magnet to get it back in.
    Took me about 15 mins
    Last Edit: May 20, 2022, 04:54:50 pm by Alahdamit
    • #3
    Offline Guy YMX
    Reply #3 on: May 20, 2022, 08:49:34 pm
    I don't want to tweak the QF, I want to slightly raise the shifter to allow easier shifting with my riding boots
    • #4
    Offline Guy YMX
    Reply #4 on: May 20, 2022, 08:53:06 pm
    *Originally Posted by Alahdamit [+]
    Thanks, that's exactly what I was looking for  :467:
  • Offline NiK   fr
    Reply #5 on: May 23, 2022, 12:17:35 pm
    *Originally Posted by Guy YMX [+]
    Adjusting the shifting lever then? I get it now ;-)
    • #6
    Offline Guy YMX
    Reply #6 on: May 24, 2022, 02:02:12 am
    Shifter adjustment was a real PIA but I managed to get it done, thanks for all your help!
  • Offline Ninja   ca
    • Explorer Pro  ‐    180
    Offline Ninja
    • Bike: Ninja 1000 SX
    • City / Town: Whiterock
    Reply #7 on: June 25, 2022, 05:55:38 pm
    How did this work out in the end,,,, I may, reluctantly, have to do an adjustment as my ADV boots don't manage the up shifts very well so the current procedure of only wearing my street boots is not a solution,,.
    I don't want to upset the quick shifter which is absolutely perfect?
  • Offline CraptainC   gb
    • Explorer Pro  ‐    412
    Offline CraptainC
    • Bike: Gen3 XCa
    • City / Town: Chester
    Reply #8 on: June 25, 2022, 10:58:08 pm
    Hello All...
    as an alternative you might want to consider fitting Pivot Pegz. I fitted these to my XCA a while back, and the definitely make operating of the gear change and rear brake levers a lot easier with both my street boots and Adv boots.
    Check out https://pivotpegz.com/collections/triumph
    CC
  • Offline dirtyduck   us
    • Explorer Member  ‐    21
    Offline dirtyduck
    • Bike: 2023 Rally Pro
    • City / Town: Southern Oregon
    Reply #9 on: October 04, 2022, 10:45:13 pm
    *Originally Posted by CraptainC [+]
    Hello All...
    CC
    FWIW I recently installed these, they do help some.  They can be installed in either standard or lowered configuration, although it doesn't lower much (8 mm/.31 inch).  Their support rep suggested trying them first at the standard height, which I did.  The pivot motion does help with the foot angle some, but I still wound up reinstalling them in the lowered configuration.  I haven't had a chance to ride with them yet, but just sitting on the bike it is easier to get my foot under the shifter.  That said I suspect I'll still have to adjust the quickshifter linkage, but really hoping to avoid that if possible.  BTW Pivotpegz are considerably longer and wider than stock, definitely an improvement in comfort.
