Home
Search
Members Map
Photos Gallery
Login
Register
Forum Rules
Forum Help
18 Aug 22, 08:27 AM
Please
login
or
register
Tiger 1200 Explorer
Tiger 1200 Explorer - Gen 4 (2022 on)
Tiger 1200 - General Discussion (Gen 4 - 2022 on)
Denali Soundbomb
18 Aug 22, 08:27 AM
Pages: [
1
Go Down
Author
Topic: Denali Soundbomb (Read 666 times)
Duffvader
Explorer Junior
Topic Author
Bike: Tiger GT Explorer
City / Town: Lowestoft
Country:
Denali Soundbomb
on:
June 22, 2022, 12:18:02 PM
Has anyone fitted one or a Split on their 22 yet?
The Denali site suggests the fitting kit for the old bike fits the new one, not convinced about that tbh
Logged
JG_XRT
Explorer Master
Up the Irons!
Bike: 2017 XRt
City / Town: Battle Creek, MI
Country:
Re: Denali Soundbomb
Reply #1 on:
June 22, 2022, 12:40:42 PM
I can't see how the mount for the previous models would work- IIRC, it bolted to the engine and/or frame (or was it radiator or crash bars) on the Gen 1-3.
Different engine, different bolts and locations.
You might be able to
make
it work.
My bracket for the Gen 2 is still hanging in my garage- I couldn't use it because my crash bars got in the way. If you use the right diameter clamp mount, it could go on your frame or crash bar.
Logged
So many roads, so little time.
Duffvader
Explorer Junior
Topic Author
Country:
Reply #2 on:
June 22, 2022, 03:38:45 PM
Ok say it did fit on my frame or crash bar, what else is required to make it work, wiring etc?
Logged
Will Morgan
Explorer Master
Bike: Explorer
City / Town: Ross on Wye
Country:
Reply #3 on:
June 22, 2022, 05:26:27 PM
As you usually get a relay with the Soundbomb you'd probably only need this wiring kit:
https://www.denalishop.co.uk/horn-wiring/114-wiring-harness-for-soundbomb-horns.html
Logged
JG_XRT
Explorer Master
Up the Irons!
Bike: 2017 XRt
Country:
Reply #4 on:
June 22, 2022, 05:29:16 PM
I bet you are looking at the clamp-style mount and not the bracket they offered for the previous models, then.
It comes with a very sturdy wiring harness and relay and the instructions are excellent.
You just have to find a suitable mounting spot, then run the wiring- order the kit Will mentioned. I forgot that was separate.
You'll tap into one side of your horn to trigger the included relay, and the relay will feed power from the batter to your horn. It's wired direct to the battery (with the relay to trigger it) because the horn draws something like 30 amps.
It's very load and get people's attention.
Logged
Lovetubs
Explorer Member
Bike: Rally Explorer
City / Town: Lincoln
Country:
Reply #5 on:
June 22, 2022, 09:56:09 PM
I've mounted a mini sound bomb tucked in the left fairing.
Used the thin mount bracket that came with it - I removed the circled bolt and slid the thin plate between the two parts, then re-inserted the bolt.
Ran a jumper cable from the original connection to the horn.
Under the plastic cover, across the top of the frame an down a gap near the radiator hoses on the left side.
Not as loud as the full unit but better than the original horn.
Hope this helps.
Lovetubs
Having just watched the video from Guy YMX on the Side Panels Gen 4 thread, I’d say it’d make the routing of the cables much easier.
Last Edit: June 22, 2022, 10:29:19 PM by Lovetubs
Logged
Duffvader
Explorer Junior
Topic Author
Country:
Reply #6 on:
June 23, 2022, 09:55:51 AM
I am thinking under the beak maybe
Logged
Icy
Explorer God
Stationary Traveler
Bike: 2018 TEX XCx
City / Town: Bronxville, NY
Country:
Reply #7 on:
June 23, 2022, 09:29:38 PM
Originally Posted by
Lovetubs
Hope this helps.
Lovetubs
Logged
Duffvader
Explorer Junior
Topic Author
Country:
Reply #8 on:
June 24, 2022, 09:30:52 AM
Lovetubs
Thanks for that, Denali have come back to me, there is no kit for the new bike (or one coming) and he suggested trying a universal crash bar adapter but I dont think the Tiger bars are big enough to take the bomb and bracket
https://www.denalishop.co.uk/horn-mounts/147-horn-mount-universal-bar-clamp-21mm-29mm-black.html
Logged
B1957
Explorer Member
Bike: 2022 Rally Pro, T120
City / Town: Canberra
Country:
Reply #9 on:
June 27, 2022, 08:29:54 AM
Not sure if this will help as I haven’t got to it yet on my 2 day old 1200, but this what I did on my 900 and intend do something similar on the 1200.
Essentially I mounted 2 flat strips of springy steel (that I think came with the horn) to 2 of the engine cover bolts, forming a triangular mount. I then ran piggy back wires from the stock horn, which I left in place, and didn’t use a relay. The Sick Speed horn is a big improvement over the stock horn alone although it isn’t anywhere near as loud as an air horn. However, as I couldn’t find anywhere to put an air horn on the Tiger it was a simple and effective alternative.
Logged
Pages: [
1
Go Up
High flow air filter DNA
Meese
Today
at 02:47:44 AM
Fuel Filter? What Fuel Filter !
General Maintenance and Servicing
GerPa
Today
at 02:25:43 AM
Clutch biting point
Tiger 1200 Explorer - General Discussion
GerPa
Today
at 02:16:36 AM
"It's not unusual" . . .
GerPa
Today
at 01:51:28 AM
Be careful with your Shoei Neotec 2 helmet
Riding Gear, Clothing, Apparel
Hawkeye
Yesterday
at 11:06:58 PM
Trumph Gen 4 Key Barrel in GIVI Dolomite / Trekker case
Stotty
Yesterday
at 10:17:25 PM
new member
New Members
CraptainC
Yesterday
at 09:38:02 PM
Which Tail bag ?
Accessories and Products
CoreyPeters
Yesterday
at 08:57:55 PM
Starter Switch not working issue.
"How To" Technical Articles
farrow
Yesterday
at 07:39:39 PM
New owner
New Members
CraptainC
Yesterday
at 05:35:25 PM
