Author vibration front brakes XCA 1200 2018 8000 miles  (Read 1449 times)
  • Offline Telbags   gb
    • Explorer Member  ‐    17
    Offline Telbags
    • Happiest when on two wheels
    • Bike: XCA 2018
    • City / Town: Ormskirk Lancs
    on: September 20, 2022, 08:46:38 pm
    hi all,
    Hi everyone...
    my machines front brakes have started to vibrate at low speed, just as i come to a stop.
    The brake pads were apparently changed under warranty when the bike was with the previous owner, so i'm assuming they're fine.
    I've removed pads, cleaned, reassembled them and they were fine for a few hours but then it's back again.
    any ideas what i should look for/try?            :027:
    is this a known issue? I wonder why the dealer changed the brakes without charge?
    All Bikes are equal. But some Bikes are more equal than others.
  • Offline CraptainC   gb
    • Explorer Pro  ‐    436
    Offline CraptainC
    • Bike: Gen3 XCa
    • City / Town: Chester
    Re: vibration front brakes XCA 1200 2018 8000 miles
    Reply #1 on: September 20, 2022, 09:02:02 pm
    Hi Telbags,
    I seem to remember call there being a recall due to brake pads delaminating on the 2018 model.
    As for the vibration, I wonder if one of you front disks is slightly warped and/or brake cylinder a bit sticky?
    CC
    • #2
    Offline Telbags
    • Bike: XCA 2018
    Reply #2 on: September 20, 2022, 09:51:27 pm
    that explains the pads change at the dealers... :028: thanks!
    hoping not the discs, there's no vibration in the bars, but there is a high(ish) pitched squeal... was thinking it could just be the pads vibrating, but ive reassembled, put copper ease behind the pads, cleaned everything thoroughly... and the retaining mechanism seems tight and effective?
    just stumped as to what it could be... :033:
    i could ask the dealer to sort but my local Triumph dealer is £100 per hour!
  • Offline NiK   fr
    • Explorer God  ‐    5372
    • Country: fr
    Reply #3 on: September 21, 2022, 09:36:07 am
    Squealing brakes is very common on Triumph (all of my five did it sooner or later).
    As long as your pads are not completely worn and your caliper pistons are not stuck, this doesn't impact braking performance.
  • Online T800XC   england
    • Explorer Master  ‐    1415
    Online T800XC
    • Bike: Tiger 900 Rally Pro
    Reply #4 on: September 21, 2022, 10:20:36 am
    *Originally Posted by Telbags [+]
    ...my machines front brakes have started to vibrate at low speed, just as i come to a stop.
    I've had a similar issue for some time (at least since my front brake pads were replaced under the recall), but recently it appears to be much more noticeable.
    See more info here...
    https://www.tiger-explorer.com/index.php/topic,21180.0.html
  • Offline XCaTel   ie
    • Explorer God  ‐    2854
    Reply #5 on: September 21, 2022, 11:25:47 am
    You should also makes sure the brake rotor buttons are free of crud and moving allowing it to float.
    • #6
    Offline Telbags
    • Bike: XCA 2018
    Reply #6 on: September 22, 2022, 06:29:42 pm
    Hadnt thought of that....checking.... :467:
    • #7
    Offline Telbags
    • Bike: XCA 2018
    Reply #7 on: September 22, 2022, 06:34:11 pm
    i seem to have resurrected this topic... i'll try it out on differnt modes to see if theres an internal/system reason for the phenomenon but will clean the floating bobber things, too...
    cheers for all the good feedback...great to have more experienced minds doing the hard thinking!  :152:
