Author Bike has died.  (Read 1832 times)
  • Offline matepatepa   gb
    • Explorer Junior  ‐    12
    Offline matepatepa
    • Bike: Tiger 1200 XRX
    • City / Town: Newton Abbot
    Bike has died.
    on: September 29, 2022, 08:04:00 am
    Bike died on me tonight, used it to and from work, but when I tried to go out tonight the dash went haywire when turning key on. Then no power, so managed to get another battery on and dash back on but will not fire up. When ignition turned on can hear priming noise but nothing at all when start button pressed. Alarm warning light on solid red all the time. Any ideas, bike is 1200 xrx 2017 model. Help!!!! Have checked all the obvious like kill switch. First 2 pics are of dash with old battery. No warnings now with new battery, just the warning lights on.
  • Offline jures   si
    • Explorer Pro  ‐    197
    Offline jures
    • Bike: Tiger 12GT Explorer
    • City / Town: MEDVODE
    • Country: si
    Re: Bike has died.
    Reply #1 on: September 29, 2022, 08:02:17 pm
    If nothing at all after startup - starter or starter solenoid?
    I guess you checked fuses….all but especially main ones (abs, tsas, other safety ones)
  • Offline Will Morgan   gb
    • Explorer Master  ‐    1684
    Re: Bike has died.
    Reply #2 on: September 29, 2022, 11:04:53 pm
    And have you checked for error codes?
    In case you don't know how....hold down up/down scroll button on left switch & then turn on ignition (sorry I can't remember which way to hold down scroll button so switch off ignition try the other way too!). It will give you a list of error codes in left section of display. Error codes are shown in 2 lists = engine & chassis.
    If you search the forum there is a list of what error codes mean.
    • #3
    Offline matepatepa
    Re: Bike has died.
    Reply #3 on: September 30, 2022, 06:20:32 am
    Thanks Will,  going to give it a try.
    • #4
    Offline matepatepa
    Re: Bike has died.
    Reply #4 on: September 30, 2022, 06:23:45 am
    *Originally Posted by jures [+]
    Hi Jures, yes have checked all fuses, everything works, lights, indicators, horn, heated seats, grips. Just the immobiliser light stays on solid red and bike will not start when button pressed. When ignition turned on you can hear it prime but then nothing turns over or clicks when start button pressed.
  • Offline jures   si
    Offline jures
    • Country: si
    Re: Bike has died.
    Reply #5 on: September 30, 2022, 06:43:53 am
    Well thats important info. Tried second key?
  • Offline jures   si
    Offline jures
    • Country: si
    Re: Bike has died.
    Reply #6 on: September 30, 2022, 06:47:02 am
    Check also cables (connector) going to kill switch. When raising the handlebar itbhappened to me it jumped out with exact symptons
    • #7
    Offline matepatepa
    Re: Bike has died.
    Reply #7 on: September 30, 2022, 10:01:26 am
    Yes, have tried both keys.
    Re: Bike has died.
    Reply #8 on: September 30, 2022, 10:14:21 am
    Just at thought.....
    When you changed the battery did you inadvertently disturb any of the multi pin connectors for the engine or chassis ECUs ?
    It might be worthwhile giving them a wiggle & make sure they're pushed home 100%.
    • #9
    Offline matepatepa
    Re: Bike has died.
    Reply #9 on: October 01, 2022, 11:28:55 am
    So managed to get error codes up by holding in both the select switch and up scroll button and turning on ignition. Error codes are as follows:
    P1640 and C1104
    P1698 and C1104
    P16A2 and C1104.
    Found that P1698 is 5V sensor supply problem.
    Any idea what the other codes are?
    Is this the ECU knackered?
