Home
Search
Member Map
Photos Gallery
Login
Register
VIEW MEMBERS
ERROR LOG
MAINTAIN DATABASE
ATTACH & AVATARS
MANAGE THEMES
BLOCK LIST
Login/Register
RECENT POSTS
UNREAD TOPICS
UNREAD REPLIES
PHOTOS GALLERY
HELP PAGES
ACCOUNT
SETTINGS
FORUM
PROFILE
MY POSTS
MESSAGES
NEW = 0
LOGOUT
Recent Posts
Please
login
or
register
LOGIN
JOIN
Tiger 1200 Explorer
Tiger 1200 Explorer - Gen 1 to 3 (2012-2021)
Alarms, Immobilisers, and Security
Keyless malfunction
01 Feb 23, 18:23 pm
1
2
Go Down
Author
Keyless malfunction (Read 694 times)
mmotors
Explorer Junior ‐
10
Topic Author
mmotors
Explorer Junior
Topic Author
Bike: Triumph Tiger 1200 XRT
Country:
Keyless malfunction
on:
January 19, 2023, 06:43:50 am
Hi. Yesterday I was recharging the battery and after put it on again and connect the cables run the bike with no problems( I had an issue with startitg, thats why recharged the battery), turn off the bike and after a while I've tried to start it again, but there was a red light flashing on top of TFT display, and doesn't turn on. The key was in my pocket. I tried several times with turning of and on the switch, the red light is flashing. I succeed to turn on and start the bike after several attempts.
This happened to me for the second time( I own the bike from 1 mounth only) Is enybody have expirienced such a problems? Thank you.
T800XC
Explorer Master ‐
1338
T800XC
Explorer Master
Bike: Tiger 1200 XRT
City / Town: English Riviera
Country:
Re: Keyless malfunction
Reply #1 on:
January 19, 2023, 07:26:07 am
I keep the keyfob in my left trouser pocket when riding and it's very reliable if I'm sat on the bike or stood on the left side. It's not so reliable if I'm stood on the right or a couple of feet away.
When I'm working on my bike I often find I need to leave the keyfob on the seat or top of the tank.
It might be worth changing the battery in the keyfob as that can also cause problems due to a weak signal.
KenW
Explorer Master ‐
1970
KenW
Explorer Master
Bike: 2018 Tiger 1200 XRt
City / Town: Adelaide
Country:
Reply #2 on:
January 19, 2023, 08:05:26 am
If I have to charge the battery (very rarely), I don't disconnect it from the bike, just clip charging leads onto it in situ, or connect via the Hella socket forward of the tank.
tdragger
Explorer Member ‐
55
tdragger
Explorer Member
Bike: 2023 GT Explorer
City / Town: FREDERICKSBURG
Country:
Reply #3 on:
January 19, 2023, 01:30:18 pm
Originally Posted by
mmotors
I'm having the same fits with the key fob. Changed the battery in it and still having issues with the bike failing to unlock. There seems to be some validity to the "cold temperature" issue as I have experienced it myself. I've had to go so far as to remove the seat and set the fob practically on the sensor to get the bike to pick it up.
James Epley IBA #609
2023 Triumph Tiger 1200 GT Explorer
2015 Triumph Trophy SE
Iron Butt Rally Finisher - 2019, 2021 (Gold)
Mark Carter
Explorer Pro ‐
106
Mark Carter
Explorer Pro
It's not the years, it's the mileage!
Bike: Explorer 1215
City / Town: Romsey
Country:
Reply #4 on:
January 19, 2023, 06:05:04 pm
Keyless ignition, a solution still searching for a problem.
Explorer God ‐
7162
Explorer God
Bike: 2012 TEX
City / Town: Harlan, Iowa
Country:
Reply #5 on:
January 20, 2023, 12:46:22 am
I love the keyless ignition on our SUVs, but don't really think I need the headache that the fobs on these newer Tigers seem to have.
mmotors
Explorer Junior ‐
10
Topic Author
mmotors
Explorer Junior
Topic Author
Country:
Reply #6 on:
January 24, 2023, 06:45:14 am
https://youtu.be/l-BT3uokvDA
I've changed the battery of the fob and did that described procedure. It's really strange decision of Triumph engineers with those moving contacts
Hope, that the problem is fixed.
T800XC
Explorer Master ‐
1338
T800XC
Explorer Master
Country:
Reply #7 on:
January 24, 2023, 01:10:41 pm
The keyless ignition system and keyfobs are designed and built by Pektron who are 'specialist' automotive electronics designers and make ECUs and entry systems for many major manufacturers. But that doesn't mean they don't have their faults.
The contacts under the battery are not 'moving' because they wrap-around the PCB to mate with gold plated circuit traces on both sides. They're also sprung to (hopefully) maintain a decent contact. I can't see why not to solder these though. The gold plating keeps tarnishing to a minimum and reduces contact resistance, but if the mating part is not gold plated or is not held in tight contact then problems can arise. Also any dirt ingress can easily cause problems. Looking closely at the design I'd be more wary about the single-point contact for the +ve terminal, but it does at least have some spring to it so should be held under pressure to ensure a firm contact when the case is assembled.
The following images from their FCC filing shows what the keyfobs look like inside, so you can see how the contacts are arranged:-
mmotors
Explorer Junior ‐
10
Topic Author
mmotors
Explorer Junior
Topic Author
Country:
Reply #8 on:
January 24, 2023, 04:53:08 pm
T800XC
Neither do I. Đ¢his is a prerequisite for problems! My opinion.
Thanks for the pictures
jures
Explorer Pro ‐
220
jures
Explorer Pro
Bike: Tiger 12GT Explorer
City / Town: MEDVODE
Country:
Reply #9 on:
January 25, 2023, 05:44:40 am
You need to carefully solider both contacts coming down from battery. My key was disconnecting randomly, after I solidered fixed the 2 (square) contacts. All problems went away
1
2
Go Up
Speed restriction???
Tiger 1200 - General Discussion (Gen 4 - 2022 on)
Bobhead65
Today
at 05:16:06 pm
Denali Electronics Controllers for Gen 4
nhsdave
Today
at 09:31:53 am
Papadop88's 2023 Tiger 1200 Rally Pro Build
Whippet
Today
at 07:22:57 am
Correct Gen3 battery?
Electrical and Lighting
llama
Today
at 01:25:14 am
After market shield options?
Meese
Yesterday
at 11:47:42 pm
After Market LED Spot Lamps
General Maintenance and Servicing
Sheriff1215
Yesterday
at 10:51:06 pm
Keyless malfunction
soft
Yesterday
at 08:35:19 pm
Heated grips switching themselves off
keoweetiger
Yesterday
at 11:56:06 am
Givi PLO6422MK Pannier Holders
sd12tiger
Yesterday
at 09:01:49 am
Aftermarket exhaust
Bobhead65
Yesterday
at 07:43:34 am
