Hi Guys,
I have a Desert Edition, and bought some TM MIssion, the following ones : FRONT: 120/70B19,REAR : 170/60B17, but when you go on the Dunlop site, they recommend the following for the Desert Edition , FRONT: 120/70ZR19 REAR : 170/60ZR17.
Difference is B and ZR (Z will be speed). I am totaly lost on this subjects. For tigers with mags, they recommend the 'B' and the Tigers with spoke Wheels the 'ZR' . my knowledge is very limited on tyres, but I beleive B is Bias, and R are Radial .... but why one has the B and the other as the R... same bikes, different wheels, why one Bias and the other Radial ..... totally lost here.
Wrote to Dunlop, and they answered this :
I’m showing the Triumph Tiger 1200 Desert Edition has the Trailmax Mission recommended and the Roadsmart III as an option. The Triumph Tiger 1200 Alpine Edition Roadsmart III recommended and the Trailmax mission as an option. ZR are street tires with max speed of 149 mph rating, the R stands for radial. The B is for Belted Bias ply tire. Standard motorcycle tires have 3 options Bias, Belted Bias and Radial which are the tires construction. The Desert Edition runs a tubeless spoke wheel so if you have the desert edition there should be no issues with the Trailmax Mission. The only drawback is the Trailmax mission is only rated for 118 mph , The Trailmax Mission is a bias ply tire since it is targeted for off road use. The load index will match or be above the recommended OE tire fitment. It can be used with or without a tube. The only draw back would be speed rating the ZR would be a 149 mph tire where the Trailmax mission is a T rated = 118 mph. Feel free to contact me with any additional questions you may have.
So do you think I'm still good with the 'B' or should go with the 'ZR' - like I said totaly lost , and want to make sure that I'm good with the ones bought for Road Touring, heavy loads, and some light off road.
Is Radial better than Bias? need help guys and girls...
Thanks/Merci
