Author New Indicators  (Read 415 times)
  • Offline TEX1 MATT
    • Explorer Junior  ‐    14
    Offline TEX1 MATT
    • City / Town: Merseyside
    New Indicators
    on: March 06, 2023, 05:25:44 pm
    So I've fitted aftermarket LED indicators to my Mk1. Ive added resistors to both sides and the left hand side work perfectly however the right hand side will only flash around 4 times before going off and not being able to be switched back on.
    When the bike is not running but the ignition is on the right hand side works perfectly normal.
    Ive checked connections etc but just don't seem to be able to get the right hand one to work correctly.
    Any ideas ?? :084:
  • Offline Jon   us
    • Explorer God  ‐    7197
    Re: New Indicators
    Reply #1 on: March 07, 2023, 01:00:47 am
    How many Ohm resistors did you use? You need 10 Ohm. 1 resistor per pair of lights. Perhaps one of your resistors is weak... Other than that, I got nothin. :027:
  • Offline NiK   fr
    • Explorer God  ‐    5149
    Re: New Indicators
    Reply #2 on: March 07, 2023, 02:58:21 pm
    I remember having the same symptoms years ago when I installed switchback led strips on my handguards.
    I don't remember however how I solved it (but I did)...
  • Offline NiK   fr
    Re: New Indicators
    Reply #3 on: March 07, 2023, 03:02:23 pm
  • Offline Blackiecram
    • Explorer Junior  ‐    5
    Offline Blackiecram
    • City / Town: Durham
    Re: New Indicators
    Reply #4 on: March 17, 2023, 09:10:00 pm
    Got same issue bought led indicators advertised with resistors built in, issue is won't stay on unless I leave fingers pushed over on indicator switch and flash very quick where do I fit the additional resistor and do only need 1 10 ohm per side?
  • Offline JG_XRT   us
    • Explorer Master  ‐    632
    Re: New Indicators
    Reply #5 on: March 17, 2023, 10:19:07 pm
    I'm not sure what indicators you bought.
    I bought these and have never had an issue with hyperflash.  Installed in 2018 on my Gen 2.
    I did have to grind off 1 locking post on each bulb.
    Might be easier to swap bulbs than wire up resistors.
    So many roads, so little time.
