Well Fourm Members, Feedback time.
6/2016 XCa with just 30072Klms on it I am its 3rd owner it had 18,000klms on it when I purchased it so there is I'm My opinion a bit of concern about the previous treatment, thus do the maintenance and draw a line in the sand as I did when I got all the Engine Stuff down at 20,000klms
I bit the bullet this afternoon and stripped the Rear Suspension Link, I had Mark's Motorcycle Manual to assist and follow which certainly makes life a bit easier. However, I had to remove the exhaust to get the Rear/Swing Arm link bolt out.
Once everything was removed it was as expected. 7yr old aged limited amount of grease and it's impossible for it to be any other way. as the tolerances between the Pins and the Needle Rollers is so precise that any excess grease is pushed out when reassembling it. there was no sign of any dirt or water ingress however the lower Shockie Eye Link Pin had some slight blueing when the pressure had been applied to it at some time. there was absolutely no wear in any of the pins. there were some minor wear marks on the inside of the Rear Swing Arm links where they touched the side of the Aluminium link.
I cleaned all the Needle Roller bearing in the link and repacked them with some fresh Heavy Duty grease,
N.B. Be very careful cleaning the Needle rollers in the Bottom of the shockie as they're not captive like the Link bearings and will all fallout and you then have to take extreme caution repacking and reseating them correctly in the Lower Shockie Eye.
All up it took about 3Hrs which in My Opinion is not too bad for a Mature Aged Motorcycling Enthusiast (73) rolling around on the ground because He had sold his service ramp with the sale of the the last Triumph Thunderbird and the Ol Harris Bonneville.
