Author Pyramid "Extenda fenda EXTRA"  (Read 4554 times)
  • Offline Lovetubs   gb
    • Explorer Member  ‐    51
    Offline Lovetubs
    • Bike: Rally Explorer
    • City / Town: Lincoln
    Re: Pyramid "Extenda fenda EXTRA"
    Reply #10 on: November 17, 2023, 09:33:54 am
    Do you have them fitted Bruce? If so did you use the adhesive strips or the rivets to secure them? I saw the other info on the pyramid website last night but was wanting to know if anyone with a RE actually has the experience of having them on their bike.
    Lovetubs
    Tiger 1200 RE
    Tiger 1200 Gen1
    Suzuki VStrom 650
  • Offline BasilB   au
    • Explorer Pro  ‐    331
    Offline BasilB
    • Bike: 2023 Tiger GT Explorer
    • City / Town: Hobart
    Reply #11 on: November 17, 2023, 09:13:57 pm
    *Originally Posted by Lovetubs [+]
    Lovetubs
    This on a GTX but it's the same as the RX. Even with rivets you do use some double sided tape to secure the edges. These need to be clamped for a while to make sure the adhesive holds in place.
  • Offline Bruce Wayne   nl
    • Explorer Pro  ‐    443
    Offline Bruce Wayne
    • Bike: 1200Tiger Rally Explorer
    • City / Town: Winterswijk
    • Country: nl
    Reply #12 on: November 19, 2023, 12:00:32 pm
    Lovetubs
    No not yet. But a fellow RE driver, in the Netherlands, has the front one installed and not even used the rivets. Only the tape. The braces are extremely solid, he stated.
  • Offline KennyDies   gb
    • Explorer Member  ‐    71
    Offline KennyDies
    • City / Town: Bournemouth
    Reply #13 on: November 20, 2023, 10:59:00 am
    I used the strips and the mounts.  Didn't use the rivets.
    The only issue I had is the instructions are not clear the strips should be on and i stuck them to the wrong side
  • Offline trade_nancy   nz
    • Explorer Pro  ‐    129
    Offline trade_nancy
    • Bike: 2018 1200
    • City / Town: Manawatu
    • Country: nz
    Reply #14 on: November 20, 2023, 09:02:05 pm
    Mine is on  Gen3..but having looked at the gen4 guard front - no diff. Absolutely worth it. Your radiator(s) are different mounts. So your "impact" from detritus may be less. But on Gen 3 the large central radiator fan attracted small road chips. TWICE my bike overheated on separate rides...and when I checked the radiator I found small chips wedged between fan blade tip and the shroud. Enough to stop the fan starting.
