Author Rear brake pedal broken… not sure what’s missing  (Read 658 times)
  • Offline 20231114   au
    • Ex Member
    • Explorer Member  ‐    43
    Offline 20231114
    • Ex Member
    on: September 21, 2023, 12:55:43 pm
    My rear brake pedal freely rotates between the high and low rotation setting.
    I assume something has come off it. Can someone please post a closeup of what keeps it in the position you set it to?
  • Offline 1675   gb
    • Explorer Member  ‐    93
    Offline 1675
    • Bike: GT Explorer
    • City / Town: Spennymoor
    Re: Rear brake pedal broken… not sure what’s missing
    Reply #1 on: September 22, 2023, 08:53:11 pm
    Can you post a photo of the problem you are experiencing?
    • Ex Member
    • #2
    Offline 20231114
    • Ex Member
    Reply #2 on: September 22, 2023, 11:16:26 pm
    My phone camera is busted due to vibration I’ll post one when the Mrs is next near the bike.
    The rear brake lever has a high and low setting where the section at the front can be pulled out and rotated 180degrees into high or low setting and then there is a spring (I assume) that should hold it in.
    Mine just rolls around from high to low as I assume the spring that retains it in high or low is missing.
    • Ex Member
    • #3
    Offline 20231114
    • Ex Member
    Reply #3 on: September 22, 2023, 11:19:21 pm
    i=jYTVnsHEmHk2s72u
    In this they make the adjustment from high to low. (not the section where he is using tools)
  • Offline BasilB   au
    • Explorer Pro  ‐    331
    Offline BasilB
    • Bike: 2023 Tiger GT Explorer
    • City / Town: Hobart
    Reply #4 on: September 23, 2023, 01:14:05 am
    Woah I never knew the pedal had an upper and lower setting!
    • Ex Member
    • #5
    Offline 20231114
    • Ex Member
    Reply #5 on: September 23, 2023, 09:43:05 pm
    They do… till they dont… helps for dialling it in without tools when swapping between on and offroad ergos.
    I spend most of my time standing on the pegs so would normally lift my lever, making it an awkward angle when sitting. This (if it was more reliable) takes that issue away, best of both worlds.
  • Offline 1675   gb
    Offline 1675
    • Bike: GT Explorer
    Reply #6 on: September 23, 2023, 10:26:00 pm
    I don't think all models have this feature. I have a GT Explorer and mine doesn't have it, not that it bothers me.
    Perhaps it only applies to the wire wheeled, off road based machines?
    • Ex Member
    • #7
    Offline 20231114
    • Ex Member
    Reply #7 on: September 24, 2023, 12:59:19 am
    If thats the case Ill ask for the GT one when I go in for the warranty check and and just set it up in a permanent higher position than normal for road.
    Would rather the ergos being off a little when I am on the road than having this broken rotating issue.
