Author Check engine light on  (Read 1453 times)
  • Offline papaw   us
    • Explorer Member  ‐    30
    Offline papaw
    • Bike: 23 Tiger1200 GTExplorer
    • City / Town: Orange, Texas
    on: February 09, 2024, 09:50:49 pm
    I had to disconnect my battery due to my Thunderbox not working.  After I got that sorted out I couldn't get the bike to start.  Disconnected battery again and for some reason the engine started but now I have a check engine light that won't go out.  I did have to reset my time and date.  Any ideas??????
  • Offline keoweetiger   us
    • Explorer Pro  ‐    106
    Offline keoweetiger
    • Bike: Tiger 1200 GT Explorer
    • City / Town: SENECA
    Re: Check engine light on
    Reply #1 on: February 10, 2024, 12:46:49 am
    These bikes seem to exhibit all kinds of errors when the battery is disconnected.  Maybe try to recycle it a few times, drive it a few miles, etc.
  • Offline Guitarman   gb
    • Explorer Pro  ‐    128
    Offline Guitarman
    • Never too old.
    • Bike: Tiger 1200 XRT / T350J
    • City / Town: Inverness
    Reply #2 on: February 10, 2024, 08:37:17 am
    Normally three cycles to clear after removing the battery.
  • Offline papaw   us
    • #3
    Offline papaw
    Reply #3 on: February 13, 2024, 10:20:56 pm
    Well the good news is that the bike started with no check engine light today.  But the Thunderbox did not power up my Garmin until I had been riding about an hour.
  • Online Speed_Racer   us
    • Explorer Pro  ‐    111
    Online Speed_Racer
    • Bike: XCa + Explorer
    • City / Town: Utah, USA
    Reply #4 on: February 13, 2024, 10:33:31 pm
    How's the voltage on that battery? With both the no-start and TB delay symptoms, it sounds like it might need a trickle charge?
    '18 XCa, '13 TEx, '08 Striple, '13 T100...
  • Offline BasilB   au
    • Explorer Pro  ‐    418
    Offline BasilB
    • Bike: 2023 Tiger GT Explorer
    • City / Town: Hobart
    Reply #5 on: February 14, 2024, 02:06:17 am
    *Originally Posted by papaw [+]
    I've got the Thunderbox and it should power up as soon as the ignition is turned on. Are you sure it is wired correctly. What did you do with the white wire?
    If the bike started then there should be enough power for the TB.
  • Offline papaw   us
    • #6
    Offline papaw
    Reply #6 on: February 15, 2024, 03:33:53 pm
    I did not connect the white wire as the instructions said.  However, today the thing is working.  Seems to be an intermittent problem.  Going to send an email to the manufacturer since there seems to be no way to talk to a real person.
  • Offline BasilB   au
    Offline BasilB
    Reply #7 on: February 16, 2024, 01:08:57 am
    From memory it is more reliable when using the white wire. I connected to rear din power wire and it works perfectly.
  • Online sirsidneyrd   gb
    • Explorer Master  ‐    1940
    Online sirsidneyrd
    Reply #8 on: February 16, 2024, 08:44:36 am
    If the battery voltage gets too low the service light comes on and the date and time need resetting - happened a couple of times on mine - I don’t use a tender
  • Offline papaw   us
    • #9
    Offline papaw
    Reply #9 on: February 16, 2024, 04:00:03 pm
    Yes I have had to reset date and time when battery has been disconnected.  Answer came back from Healtech, that I should connect the white wire to a switched powered wire and see if the problem happens again.  This is what I wanted to avoid in buying the Thunderbox.  Now I have to decide what is the least invasive switched wire to use, though that makes the Thunderbox pointless.
