Author Shift up power loss tex 2015  (Read 465 times)
  • Offline farmaceuta   pl
    • Explorer Junior  ‐    2
    Offline farmaceuta
    • Bike: TEX 2015
    • City / Town: BB
    • Country: pl
    on: February 10, 2024, 10:00:35 pm
    Hello,
    I got a strange behavior on my TEX 2015, it is happening not in all time , happens especially at start of a ride, when i'm shifting up especially from 2nd to 3rd gear and higher (never happens from 1st to 2nd) i got sometimes a sudden power loss for 1-2 seconds, TC light is visible at this time, after this short time it is running without problems. Does anyone has similar issues ?
    Best Regards !
  • Offline Jon   us
    • Explorer God  ‐    7466
    Re: Shift up power loss tex 2015
    Reply #1 on: February 11, 2024, 01:24:55 pm
    I assume that when this happens, it's always under hard acceleration and always for a brief moment. If so, it is indeed your TC kicking in preventing wheelspin. That's the way it's designed. To test it, you can turn off TC and see if you still "lose power" or if your bike spins the rear tire. Someone else can chime in if there can be an actual problem with the traction control, but I don't recall hearing of an actual issue with TC.
    • #2
    Offline farmaceuta
    • Bike: TEX 2015
    • City / Town: BB
    • Country: pl
    Reply #2 on: February 11, 2024, 04:52:34 pm
    Sadly it is not only under hard acceleration, more ever after it appears 2-3 times later it is not happening for hours.
  • Offline NiK   fr
    • Explorer God  ‐    5481
    Reply #3 on: February 12, 2024, 01:22:14 pm
    Ruling out back wheel spin is not that simple I'm afraid.
    It depends on the road condition, and above all you tires: a cold crappy Chinese rubber surely doesn't provide the same traction as a warm Michelin.
    Now if you are able to rule out normal TC behavior, a slipping clutch may (or may not) cause the same symptom (at least it did on my old car), even if I'm not sure how it would not appear in the first two gears.
