Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Final drive oil change  (Read 16074 times)
Re: Final drive oil change
« Reply #60 on: November 16, 2018, 04:23:03 PM »
I fill mine to the point that it seeps out while on the center stand. Some say that you should level the bike first by putting a piece of wood under the front tire. I don't bother. And I don't measure the amount of gear oil that I put in.
Offline FL_Explorer
  • Never take a laxative & a sleeping pill together
  • Bike: '14 Tiger Explorer
  • City / Town: Dade City, FL
« Reply #61 on: November 16, 2018, 10:18:22 PM »
To the guy who opened his plug and it started oozing out, just drain the drive and refill. Nothing to worry about. It was that full all the miles you’ve been riding it. If you hadn’t opened it, you’d never have known.
Ride safe, and ride often!
Keith
Offline Sidi1200
  • Bike: Phantom Explorer
  • City / Town: Sydney
« Reply #62 on: April 05, 2019, 07:16:45 AM »
Changed the fluids of my GEN1 today..
The Diff oil and the Magnetic Exit Plug was covered in gunk..
old Oil..
 then new oil and Plug cleaned..
Anyone can make it complicated..... Its pure Genius to make it Simple....
A Scotsman once told me that "the best glass to drink whisky out of, is the one that doesn't leak"
« Reply #63 on: April 05, 2019, 04:45:46 PM »
Wow, that's a pretty big chunk of metal stuck to that drain plug magnet.  :038:
« Reply #64 on: April 06, 2019, 09:36:16 PM »
 :745:
Offline coolhand
  • Bike: Explorer 1200 (2012)
  • City / Town: Laksevåg
  • Country: Norge
« Reply #65 on: April 08, 2019, 11:00:11 AM »
Oil discussuions tend to be like discusstions about religion: Nobody believes anything the other one says  :745:
About oil: I change the oil as the workshop manual tells me to. I use oil with the specs (or higher)  that the manual asks for. As for the brand, I don't care. I use wellknown brands, that's all.
I have driven bikes since 1994, most of them well past 100 000 km. No problems that could be attributed to oil.
As for the final drive, I know that Triumph says it does not need to be changed more than once. For this I make an exception: I change it when I chekc/adjust valve clearances. No connection between the two, but that gives me a reasonable service interval on the final drive. Do I think it is really necessary? No. I just do it to make sure.
« Reply #66 on: April 08, 2019, 05:05:01 PM »
For the cost (in time and oil) changing the final drive oil regularly is probably the cheapest and easiest insurance that you will ever buy. And literally, a child could do it.
« Reply #67 on: April 08, 2019, 06:18:58 PM »
+1   :152:
Offline Sidi1200
« Reply #68 on: April 08, 2019, 11:29:46 PM »
I agree, that it is an easy, cheap form of maintenance /care. A Point, is that a Magnetic plug is used as standard in the diff. ? So, me thinks that there is a Really good reason that 'T' did that, and not put a Magnetic Plug in the Engine Sump as standard too ?. Therefore, a really good reason to change the diff fluid at some interval...   :028:
