Home
Search
Members Map
Photos Gallery
Login
Register
Forum Rules
Forum Help
18 Aug 22, 09:14 AM
Please
login
or
register
Tiger 1200 Explorer
Tiger 1200 Explorer - Gen 1 to 3 (2012-2021)
General Maintenance and Servicing
Gearbox problem - 3rd to neutral..
18 Aug 22, 09:14 AM
Pages:
1
88
89
90
91
92
95
Go Down
Author
Topic: Gearbox problem - 3rd to neutral.. (Read 236184 times)
0 Members and 4 Guests are viewing this topic.
#890
CaptainTrips
Explorer God
Bike: '13 Explorer
City / Town: Vancouver(ish)
Country:
Reply #890 on:
August 30, 2021, 06:26:24 PM
Originally Posted by
D.M.
I fixed mine last week, start to finish took 45 mins and was dead easy. Done several hundred miles and not a single issue, so much easier to ride now.
For those of you looking to do the fix this is what I found.
1: You should only need to order 3 parts, T1194444 Shaft Assy, Pivot Gear Change (£109.31), T1261426 Gasket, Gear Change Cover (£5.35), T3550542 Washer, Cu, Od12.5 x Id6.4 (£0.58).
2: Don't bother ordering the detent wheel, springs or anything else, you "shouldn't" need them.
3: The spring does NOT go in the hole.......
I ordered basically everything just to be on the safe side since I had a shift return spring snap on my Spring 1050GT a few weeks back but, after having done the repair I would say just do the 3 parts.
My old Detent Wheel was exactly as the new one, no wear at all, the springs are much heavier then the one that snapped on my 1050 GT so don't expect them to be an issue.
There is a noticeable difference with the size of the lugs on the new Shaft Assy so I suspect this will be a permanent fix but, if not £115 and 45 mins work every few years ain't that bad....
Local Dealer said they had never heard of the issue and wanted £90 to do a diagnostic test ride so a DIY fix makes a lot of sense given how easy it is to do.
Hope this helps.
Cheers D.M.
I tend to agree. The original parts list came from the list of parts that one user received from Triumph to perform his own repair (in a country that had no Triumph dealer). I suspect that Triumph sent everything just in case. That was years ago.
I recently changed my selector shaft. I found it convenient to use the parts to build a complete shaft while having the old one in front of me to provide a model on how to assemble it. Like you, I did not end up changing the detent wheel, because the OEM service manual states that you need to remove the clutch and the gearbox in order to lock the drum to allow you to remove the bolt that holds the detent wheel. I have some pics, so I really should post them in the How-To section. I used a piece of flexible plastic to cover the holes into the gearbox, to prevent loss of the inner washer.
My opinion is that gear damage results from gears clashing that is caused by the worn selector shaft claw ends. My shaft had minor wear at 58k km when I changed it out. I am very gently on my bike when it comes to gear shifting. Always have been. I had the occasional missed or clunky shift. Seems better now. I did the change proactively to hopefully prevent future problems.
I noticed that the new shaft has claws that are rounded at one side rather than blunt. I think that Triumph has revised the part number for the selector shaft three or four times over the years.
Logged
"The test of the machine is the satisfaction it gives you. There isn't any other test."
-- Robert M. Pirsig
#891
jures
Explorer Member
Bike: Tiger XCA1200
City / Town: MEDVODE
Country:
Reply #891 on:
September 21, 2021, 08:34:29 AM
My conclusion - dogs between 2nd and 6th are worn out.....so this thing
https://www.tiger-explorer.com/index.php?topic=17129.0
It is unbeliavebly easy to repair it, the service manual, this forum - 2hours and gearbox is out. Awaiting now 2nd and 6th output gear. Not so much expensive 120€ for both + all the clips, washers, seals needed
Logged
#892
D.M.
Explorer Junior
Bike: Tiger 1200 Explorer
City / Town: Lancaster
Country:
Reply #892 on:
September 21, 2021, 09:23:42 AM
Good work Jures
Can you do us a favor? When you get the new 2nd and 6th gears can you please try to post Side by Side photos of the old and new parts showing the degree of damage along with anything else you find, this would help assess how much damage is actually being done and how likely others would be to need the same repair with similar symptoms to yours.
Post in them in the supernac thread you linked.
Cheers
D.M.
Logged
#893
Crazy Kev
Explorer Member
Bike: 1200 XCa: '88 Gsxr
City / Town: Johannesburg
Country:
Reply #893 on:
September 21, 2021, 01:15:16 PM
D.M.
Good work Jures
Cheers
D.M.
Great suggestion
Logged
“A long ride…A little more laughter, A little less worry, A little more kindness, A little less hurry.”
#894
jures
Explorer Member
Bike: Tiger XCA1200
Country:
Reply #894 on:
September 21, 2021, 01:48:55 PM
Sure will do
Logged
#895
jures
Explorer Member
Bike: Tiger XCA1200
Country:
Reply #895 on:
September 21, 2021, 05:17:29 PM
Done in other topic
Logged
#896
Speed_Racer
Explorer Member
Bike: 2013 Explorer
City / Town: Utah, USA
Country:
Reply #896 on:
September 22, 2021, 07:48:31 AM
jures
Would you mind sharing your parts order list for the 2nd/6th output gear repair? I get the "pleasure" of doing the same fix after the riding season ends - mine is exhibiting the 2nd gear pop-out issue (46k miles).
I'm going to [proactively?] replace the gearchange assembly as well but I have the parts list for that job already.
Logged
'13 TEx, '08 Striple, '12 T100
#897
jures
Explorer Member
Bike: Tiger XCA1200
Country:
Reply #897 on:
September 22, 2021, 08:50:23 AM
https://www.worldoftriumph.com/collections/100090455-0-2?type=tiger-1200-xca
New parts:
1 x 14
1 x 17
also you need to replace some clips and seals
3 x 16
1 x 12
1 x 32
1 x 7
Seal for clutch cover
https://www.worldoftriumph.com/collections/100090464-0-2?type=tiger-1200-xca
1 x 3
https://www.worldoftriumph.com/collections/100090452-0-2?type=tiger-1200-xca
Tool to remove clutch
1 x 40
Tool to remove safety bolt on drive shaft
Its either number 11 or 13 - I cant remember, but it is described in shaft removal topic, I think its 13
Thats it, 2 gears and all the one time to be used parts, and qas mentioned its for 1200 Tiger 2018.
Last Edit: September 22, 2021, 08:55:46 AM by jures
Logged
#898
CaptainTrips
Explorer God
Bike: '13 Explorer
Country:
Reply #898 on:
September 22, 2021, 11:09:30 AM
jures
New parts:
1 x 14
1 x 17
3 x 16
1 x 12
1 x 32
1 x 7
1 x 3
1 x 40
I need to pull the clutch on mine this winter. I have one of the earlier TEXs that developed a surging clutch engagement when the engine is cold. It pretty much disappears when the engine warms up, but it is very annoying. I think some replaced the clutch basket.
Logged
-- Robert M. Pirsig
#899
Speed_Racer
Explorer Member
Bike: 2013 Explorer
Country:
Reply #899 on:
September 22, 2021, 06:32:20 PM
jures
New parts:
1 x 14
1 x 17
3 x 16
1 x 12
1 x 32
1 x 7
1 x 3
1 x 40
Absolute boss
, thank you so much! I'll double check all part numbers against my 2013
Logged
Pages:
1
88
89
90
91
92
95
Go Up
High flow air filter DNA
Tiger 1200 - General Discussion (Gen 4 - 2022 on)
Meese
Today
at 02:47:44 AM
Fuel Filter? What Fuel Filter !
GerPa
Today
at 02:25:43 AM
Clutch biting point
Tiger 1200 Explorer - General Discussion
GerPa
Today
at 02:16:36 AM
"It's not unusual" . . .
GerPa
Today
at 01:51:28 AM
Be careful with your Shoei Neotec 2 helmet
Riding Gear, Clothing, Apparel
Hawkeye
Yesterday
at 11:06:58 PM
Trumph Gen 4 Key Barrel in GIVI Dolomite / Trekker case
Stotty
Yesterday
at 10:17:25 PM
new member
New Members
CraptainC
Yesterday
at 09:38:02 PM
Which Tail bag ?
Accessories and Products
CoreyPeters
Yesterday
at 08:57:55 PM
Starter Switch not working issue.
"How To" Technical Articles
farrow
Yesterday
at 07:39:39 PM
New owner
New Members
CraptainC
Yesterday
at 05:35:25 PM
