Home
Search
Members Map
Photos Gallery
Login
Register
Forum Rules
Forum Help
Contact Us
19 Jan 21, 17:49 PM
Please
login
or
register
Tiger 1200 Explorer
Main Tiger 1200 Explorer Discussion Boards
General Maintenance and Servicing
Cruise Control no more!
19 Jan 21, 17:49 PM
Pages: [
1
2
3
4
Go Down
Author
Topic: Cruise Control no more! (Read 9533 times)
Rayzor61
Explorer Member
Topic Author
Triumph is my preferred brand!
Bike: Tiger Explorer 1200
City / Town: Yardley,PA
on:
August 28, 2013, 01:16:41 PM
Just got the Tiger 1200 back from dealer service to replace the head and timing chain. Everything works fine but I just noticed the other day that my cruise control dosn't wok anymore. Not sure yet but the aux outlet might not be getting power either. I can confirm whether or not the aux outlet is working but no idea how to check for cruise control fixes. I don't think the two are related because I cant figure how Triumph would put an Aux socket on the same circuit as the crtuise control. The manual has no particular fuse for cruise control. I'm lost.
I know that the button has to be fully engaged, the bike must be in 4th gear, and you have to be rolling along at 40 mph or more. I've used it for 3250 miles. No matter what I try, it stil does not work. I tried holding the toggle switch down for several seconds, recycling the on-off ignition switch, and everything I can do to get it to work but nothing.....
The green light on the instrument cluster should come on but it doen't. Any idea's as to what the problem might be?????????????????
I don't want to roll it all the way back to the dealer (too far)...
Logged
Ride until you die and try to stay alive!
moggi1964
Explorer Master
Oldish Git
Bike: Triumph Explorer
City / Town: Sale Cheshire
Country:
Re: Cruise Control no more!
Reply #1 on:
August 28, 2013, 01:30:00 PM
I think you have to ride it back to the dealer; electronics is a dark art.
Enjoy the ride there and back
Logged
Moggi
"To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with one's ability, for I feel that life is measured in achievement, not in years alone."
Bruce McLaren
Griff
Explorer God
Bike: Explorer and others
City / Town: Wicklow
Country:
Reply #2 on:
August 28, 2013, 01:44:24 PM
Check your fuses.
Logged
Rayzor61
Explorer Member
Topic Author
Reply #3 on:
August 28, 2013, 01:52:20 PM
i dont want to do a dealer trip if avoidable.
I've read that some people have problems disengageing the cruise by use of the front brake lever (different problem). They claim to have taken the switch housing apart and it fixed it.
My problem has nothing to do with turning it off, I cant get it to go on! I would think they would have a better desscription of fuses in the manual and all the circuits each fuse covers, but they do not elaborate.
Keep ideas coming....
Logged
the burpster
Forum Moderator
Explorer Master
Bike: Explorer - HD XR1200
City / Town: Lincolnish
Country:
Reply #4 on:
August 28, 2013, 05:07:33 PM
When I stripped mine for paint work and then reassembled it, I adjusted the rear brake light switch actuator just a little too short -
It wasnt engaging the rear brake but was putting the rear brake light on intermittently. This stopped the CC working until I backed the switch back another whole turn.
Check both your brake light switches.... other than that its back to the dealer I'm afraid. :-)
Logged
"Every day you wake up is a good day!"
ayrhead
Explorer Pro
Bike: Graphite Explore
City / Town: Ayrshire
Reply #5 on:
August 28, 2013, 06:16:38 PM
I think the trip back to the dealer is unavoidable.
When my bike was in for an annual service I asked them to make sure they downloaded the most up to date tune as people had reported a much smoother cruise control action with the updated one.
It was a good few miles from the dealer before I could test it out and when I did - nothing!!
After returning to the dealer it became apparent that they need to go through an entire setup routine after updating the tune.
I guess yours has had a new tune and they did not know what to do afterwards.
Get them to collect it as it's their mistake.
Last Edit: August 28, 2013, 06:18:40 PM by ayrhead
Logged
james_uk9
Explorer Pro
Bike: Tiger Ex
City / Town: Barry
Country:
Reply #6 on:
August 28, 2013, 06:30:58 PM
Mine came back from the dealers with CC not working last time it was in.
The reset sequence worked for me so is worth a try before you make the trip to the dealers.
The conditions are Ignition key on (engine not running) and cruise control switched off:
Activate front brake switch
Rear brake switch
Clutch switch
Twist grip switch (push the throttle in the closed position)
Activate cruise on/off switch
Cruise accelerate switch
Cruise decelerate switch
Logged
#7
Rayzor61
Explorer Member
Topic Author
Reply #7 on:
August 28, 2013, 09:25:26 PM
Thanks guys,
and James, That will require quite a few hands but I will give it a try.
I will report if the reactivation method holds true.
PS: Do you have to have everything closed at the same time as you cycle the ignition key?
Logged
knobblytyres
Explorer Member
Bike: Explorer / z1000r2
City / Town: newport
Reply #8 on:
August 28, 2013, 10:27:55 PM
If it doesn't work take it back. Mine had to be plugged back in and the full diagnostic run and reset. If they don't complete the full set up and exit early cc won't work. That's what cured mine after it didn't work after a service
Logged
#9
Rayzor61
Explorer Member
Topic Author
Reply #9 on:
August 28, 2013, 10:38:22 PM
Originally Posted by
james_uk9
Rear brake switch
Clutch switch
Well I'll be dammed......
Thank you very much James.....I followed your instructions. I held all the switches open at the same time while activating the cruise on/off switch. The first time I did it, I pushed the deceleration toggle switch (-) first, and the cruise switch starting blinking.....
...than I relized your instructions were to activate the acceleration toggle first (+) then the deceleration toggle switch (-) in that order.
I held everything in place and the green light went out in 3 seconds.
I have not tried the bike on the road because it just rained here but will try it later. I am convinced that James's sequence was all it took. I know its going to work, I just know it!
THANK YOU for saving me the hassel of taking to the dealer. EVERYONE should know this if they take their bike in for service and it gets re-flashed.
Last Edit: August 28, 2013, 10:40:50 PM by Rayzor61
Logged
Pages: [
1
2
3
4
Go Up
Hi New member in Cornwall
New Members
jannerman
Today
at 05:24:55 PM
Newbie from Huntington Beach, CA, USA
New Members
CraptainC
Today
at 05:24:21 PM
RADGUARD, TIger 1200
Parts, Accessories & Clothing For Sale
Chippy4467
Today
at 04:52:41 PM
OEM rear dogbone and sensor arm
Suspension - Set-up, Repair and Mods
XCaTel
Today
at 03:44:09 PM
UK MOT Change LED Headlight Bulbs
Electrical and Lighting
XCaTel
Today
at 03:28:16 PM
Buying from Outside of the UK........an interesting Read !!!!!!!
Riding Gear, Clothing, Apparel
XCaTel
Today
at 03:24:20 PM
V18 Turbo LED headlight lamps
Cribby
Today
at 11:29:29 AM
EBC FA630HH brake pads for sale. 2 sets. Now Sold.
Reggie
Today
at 11:12:32 AM
New gen 4 is on it's way ....
Tiger 1200 Explorer - General Discussion
mjab
Yesterday
at 06:46:18 PM
exhaust mount cracking
anaheimtex
Yesterday
at 05:44:00 AM
